Noise Figure Calculations for AD9361 FCOMMS2
Question asked by SDontula on Jan 19, 2017
Latest reply on Jan 27, 2017 by sripad
  I have used Noise Source to calculate the Noise figure of the FCOMMS2 board. I have modified the Balun and the matching to adjust to the band of interest (2GHz). Using Nosie source I have captured the FFT plots (I,Q data in binary format) under Hot and Cold conditions and have calculated the Noise figure using Y factor. I want someone form ADI to review if my calculations are correct. I have used Scilab to perform the calculations. I have attached the code. I want to ensure I am converting the sum of the IQ binary data into equivalent dB value correctly. Please let me know.
Steps:
1. Read the CSV files for Hot and Cold
2. Sample Rate: 30.72MHz, Band width: 20MHz
3. Validated the quality of the data by ensuring the mean is 0 for both I & Q data
4. Performed Sqrt (I*I+Q*Q) for each bin and added all of the bins
5. Divided the result in step 4 with sample size and took real value.
6. Converted the real value in Step 5 to dB level by using the formula 20*log(real value)
7. Performed the same steps for the other CSV file (Hot and Cold)
8. NF = ENR-10*log(10^((dB_hot-dB_cold)/10)-1)
