AD9834 Output Problems
Question asked by eclipse on Sep 12, 2011
Latest reply on Dec 16, 2011 by LiamR
Hi Everyone,
I am using the AD9834CRUZ DDS chip with a 75MHz MCLK (all on an arduino shield). The chip is being programmed by an Arduino Duemilanove. I want to use it to ultimately produce a signal in the 27MHz band but currently am having trouble even getting just a 1kHz output.
What happens during testing is that when the AD9834CRUZ is powered up I instantly get a signal at the output of 2.65MHz even though I have not programmed the registers and also regardless of what frequency I even set the registers to. I decided to build another board and the same result occurs with a constant ouput of 2.65kHz regardless of frequency register.
I suspected the MCLK initially until I managed to achieve 37.5MHz output at one point but that was due to a noisy SDATA and SCLK line which has since been fixed.
Below are schematics and coding for a basic test of the AD9834CRUZ for an output of 1kHz.
Kindest Regards,
TL
  Code for programming one frequency of the AD9834.
// Global Variables
  int ChannelTransmit = 0;
  int Done = 0;
  int FreqReg0[]= {0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,1,1,0,1,1,1,1,1,1,1,0,0}; //1 kHz
  int ContReg[] = {0,0,1,0,0,0,0,1,0,0,0,0,0,0,0,0};
  int ResetReg[] ={0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0};
  int PhaseReg0[] = {1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
  int FSELECT = 8; // FSELECT pin of the AD9834CRUZ.
  int RESET = 9; // RESET pin of the AD9834CRUZ.
  int SDATA = 10; // SDATA pin of the AD9834CRUZ.
  int SCLK = 11; // SCLK pin of the AD9834CRUZ.
  int FSYNC = 12; // FSYNC pin of the AD9834CRUZ.
void setup()
  for(int pin = 1; pin < 9; pin++)
    pinMode(pin,INPUT); // Sets the AD9834CRUZ pins.
  for(int pin = 8; pin < 13; pin++)
    pinMode(pin,OUTPUT); // Sets the AD9834CRUZ pins.
  digitalWrite(FSYNC, HIGH);
  digitalWrite(RESET, HIGH);
  digitalWrite(FSELECT, LOW);
  digitalWrite(SCLK,HIGH);
void loop()
  ChannelTransmit = digitalRead(3);
  if(ChannelTransmit == LOW)
    Done = 0;
  if(ChannelTransmit == HIGH && Done == 0)
    Done = 1;
    digitalWrite(FSYNC,LOW);
    for (int i = 0; i <= 15; i++)
      digitalWrite(SDATA,ContReg[i]);
      delay(10);
      digitalWrite(SCLK,LOW);
      delay(10);
    FSYNCsetup();
    for (int i = 16; i <= 31; i++)
      digitalWrite(SDATA,FreqReg0[i]);
      delay(10);
      delay(10);
    FSYNCsetup();
      delay(10);
      delay(10);
    FSYNCsetup();
      digitalWrite(SDATA,PhaseReg0[i]);
      delay(10);
      delay(10);
    FSYNCsetup();
      digitalWrite(SDATA,ResetReg[i]);
      delay(10);
      delay(10);
    digitalWrite(FSYNC,HIGH);
    delay(10);
    delay(10);
    digitalWrite(RESET,LOW);
void FSYNCsetup()
  delay(10);
  delay(10);
  delay(10);
  delay(10);
