ADIS16488 on Raspberrypi 3 Unable to refill buffer: Connection timed out
Question asked by joesmith on Jan 16, 2017
Latest reply on Jan 17, 2017 by larsc
I'm trying to read from ADIS16488 device using libiio (iio_readdev), by this command
$ ./iio_readdev -t adis16480-dev0 adis16480
WARNING: High-speed mode not enabled
I'm using this devicetree:
* adis16480-overlay.dts
* ADIS16480 IMU (inertial measurement unit) connected to spi0 on Raspberry Pi
/dts-v1/;
/plugin/;
    compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
    /* the interrupt pin of the adis device */
    fragment@0 {
        target = <&gpio>;
        __overlay__ {
        adis_pins: adis_pins {
                brcm,pins = <25>;
                brcm,function = <0>; /* input */
                bcrm,pull = <0>; /* disable pull-over */
    fragment@1 {
        target = <&spi0>;
        __overlay__ {
            status = "okay";
            /* needed to avoid dtc warning */
            #address-cells = <1>;
            #size-cells = <0>;
            spidev@0{
                status = "disabled";
            imu@0 {
                compatible = "adi,adis16480";
                reg = <0>;
                spi-cpol;
                spi-cpha;
                spi-max-frequency = <10000000>;
                interrupt-parent = <&gpio>;
                interrupts = <25 1>; /* IRQ_TYPE_EDGE_RISING */
                pinctrl-names = "default";
                pinctrl-0 = <&adis_pins>;
Thanks in advance.
