Building library error in DAQ2
Question asked by haroldjang on Jan 12, 2017
Latest reply on Jan 13, 2017 by rejeesh
While I build library in hdl_2016_r2, I can't finish in these 2 IPs.
axi_adxcvr, util_adxcvr
Other all library is done successfully by using .tcl
But somehow these 2 folders kept Running forever.(I wait more than an hour.)
Here is the message. Please check what is wrong.
Thanks, Harold
source ./axi_adxcvr_ip.tcl
# source ../../scripts/adi_env.tcl
## set ad_hdl_dir [file normalize [file join [file dirname [info script]] "../.."]]
## set ad_phdl_dir $ad_hdl_dir
## if [info exists ::env(ADI_HDL_DIR)] {
## set ad_hdl_dir $::env(ADI_HDL_DIR)
## if [info exists ::env(ADI_PHDL_DIR)] {
## set ad_phdl_dir $::env(ADI_PHDL_DIR)
# source $ad_hdl_dir/library/scripts/adi_ip.tcl
## if {![info exists REQUIRED_VIVADO_VERSION]} {
## set REQUIRED_VIVADO_VERSION "2016.2"
## if {[info exists ::env(ADI_IGNORE_VERSION_CHECK)]} {
## set IGNORE_VERSION_CHECK 1
## } elseif {![info exists IGNORE_VERSION_CHECK]} {
## set IGNORE_VERSION_CHECK 0
## proc adi_ip_create {ip_name} {
## global ad_hdl_dir
## global ad_phdl_dir
## global REQUIRED_VIVADO_VERSION
## global IGNORE_VERSION_CHECK
## if {!$IGNORE_VERSION_CHECK && [string compare [version -short] $REQUIRED_VIVADO_VERSION] != 0} {
## return -code error [format "ERROR: This library requires Vivado %s." $REQUIRED_VIVADO_VERSION]
## create_project $ip_name . -force
## set_msg_config -id {IP_Flow 19-3656} -new_severity INFO
## set_msg_config -id {IP_Flow 19-2999} -new_severity INFO
## set_msg_config -id {IP_Flow 19-1654} -new_severity INFO
## set_msg_config -id {IP_Flow 19-459} -new_severity INFO
## set lib_dirs $ad_hdl_dir/library
## if {$ad_hdl_dir ne $ad_phdl_dir} {
## lappend lib_dirs $ad_phdl_dir/library
## set_property ip_repo_paths $lib_dirs [current_fileset]
## update_ip_catalog
## set proj_dir [get_property directory [current_project]]
## set proj_name [get_projects $ip_name]
## proc adi_ip_files {ip_name ip_files} {
## set proj_fileset [get_filesets sources_1]
## add_files -norecurse -scan_for_includes -fileset $proj_fileset $ip_files
## set_property "top" "$ip_name" $proj_fileset
## proc adi_ip_constraints {ip_name ip_constr_files {processing_order late}} {
## set proj_filegroup [ipx::get_file_groups -of_objects [ipx::current_core] -filter {NAME =~ *synthesis*}]
## foreach f_name $ip_constr_files {
## ipx::add_file $f_name $proj_filegroup
## set_property type xdc [ipx::get_files $f_name -of_objects $proj_filegroup]
## set_property processing_order $processing_order [ipx::get_files $f_name -of_objects $proj_filegroup]
## proc adi_ip_ttcl {ip_name ip_constr_files} {
## set f [ipx::add_file $ip_constr_files $proj_filegroup]
## set_property -dict [list \
## type ttcl \
## ] $f
## proc adi_ip_bd {ip_name ip_bd_files} {
## set proj_filegroup [ipx::get_file_groups xilinx_blockdiagram -of_objects [ipx::current_core]]
## if {$proj_filegroup == {}} {
## set proj_filegroup [ipx::add_file_group -type xilinx_blockdiagram "" [ipx::current_core]]
## set f [ipx::add_file $ip_bd_files $proj_filegroup]
## type tclSource \
## ] $f
## proc adi_ip_properties {ip_name} {
## adi_ip_properties_lite $ip_name
## ipx::infer_bus_interface {\
## s_axi_awvalid \
## s_axi_awaddr \
## s_axi_awprot \
## s_axi_awready \
## s_axi_wvalid \
## s_axi_wdata \
## s_axi_wstrb \
## s_axi_wready \
## s_axi_bvalid \
## s_axi_bresp \
## s_axi_bready \
## s_axi_arvalid \
## s_axi_araddr \
## s_axi_arprot \
## s_axi_arready \
## s_axi_rvalid \
## s_axi_rdata \
## s_axi_rresp \
## s_axi_rready} \
## xilinx.com:interface:aximm_rtl:1.0 [ipx::current_core]
## ipx::infer_bus_interface s_axi_aclk xilinx.com:signal:clock_rtl:1.0 [ipx::current_core]
## ipx::infer_bus_interface s_axi_aresetn xilinx.com:signal:reset_rtl:1.0 [ipx::current_core]
## ipx::add_memory_map {s_axi} [ipx::current_core]
## set_property slave_memory_map_ref {s_axi} [ipx::get_bus_interfaces s_axi -of_objects [ipx::current_core]]
## ipx::add_address_block {axi_lite} [ipx::get_memory_maps s_axi -of_objects [ipx::current_core]]
## set_property range {65536} [ipx::get_address_blocks axi_lite \
## -of_objects [ipx::get_memory_maps s_axi -of_objects [ipx::current_core]]]
## ipx::add_bus_parameter ASSOCIATED_BUSIF [ipx::get_bus_interfaces s_axi_aclk \
## -of_objects [ipx::current_core]]
## set_property value s_axi [ipx::get_bus_parameters ASSOCIATED_BUSIF \
## -of_objects [ipx::get_bus_interfaces s_axi_aclk \
## -of_objects [ipx::current_core]]]
## proc adi_ip_infer_interfaces {ip_name} {
## ipx::infer_bus_interfaces xilinx.com:interface:clock_rtl:1.0 [ipx::current_core]
## ipx::infer_bus_interfaces xilinx.com:interface:reset_rtl:1.0 [ipx::current_core]
## ipx::infer_bus_interfaces xilinx.com:interface:axis_rtl:1.0 [ipx::current_core]
## proc adi_ip_properties_lite {ip_name} {
## ipx::package_project -root_dir . \
## -vendor analog.com \
## -library user \
## -taxonomy /Analog_Devices
## set_property vendor_display_name {Analog Devices} [ipx::current_core]
## set_property company_url {www.analog.com} [ipx::current_core]
## set_property supported_families {\
## virtex7 Production
## qvirtex7 Production
## kintex7 Production
## kintex7l Production
## qkintex7 Production
## qkintex7l Production
## artix7 Production
## artix7l Production
## aartix7 Production
## qartix7 Production
## zynq Production
## qzynq Production
## azynq Production
## virtexu Production
## kintexuplus Production
## zynquplus Production
## kintexu Production
## virtex7 Beta
## qvirtex7 Beta
## kintex7 Beta
## kintex7l Beta
## qkintex7 Beta
## qkintex7l Beta
## artix7 Beta
## artix7l Beta
## aartix7 Beta
## qartix7 Beta
## zynq Beta
## qzynq Beta
## azynq Beta
## virtexu Beta
## virtexuplus Beta
## kintexuplus Beta
## zynquplus Beta
## kintexu Beta}\
## [ipx::current_core]
## ipx::remove_all_bus_interface -quiet [ipx::current_core]
## ipx::remove_all_address_block -quiet [ipx::get_memory_maps * -of_objects [ipx::current_core]]
## proc adi_set_ports_dependency {port_prefix dependency} {
## foreach port [ipx::get_ports [format "%s%s" $port_prefix "*"]] {
## set_property ENABLEMENT_DEPENDENCY $dependency $port
## proc adi_set_bus_dependency {bus prefix dependency} {
## set_property ENABLEMENT_DEPENDENCY $dependency [ipx::get_bus_interfaces $bus -of_objects [ipx::current_core]]
## adi_set_ports_dependency $prefix $dependency
## proc adi_add_port_map {bus phys logic} {
## set map [ipx::add_port_map $phys $bus]
## set_property "PHYSICAL_NAME" $phys $map
## set_property "LOGICAL_NAME" $logic $map
## proc adi_add_bus {bus_name mode abs_type bus_type port_maps} {
## set bus [ipx::add_bus_interface $bus_name [ipx::current_core]]
## set_property "ABSTRACTION_TYPE_VLNV" $abs_type $bus
## set_property "BUS_TYPE_VLNV" $bus_type $bus
## set_property "INTERFACE_MODE" $mode $bus
## foreach port_map $port_maps {
## adi_add_port_map $bus {*}$port_map
## proc adi_add_bus_clock {clock_signal_name bus_inf_name {reset_signal_name ""} {reset_signal_mode "slave"}} {
## set bus_inf_name_clean [string map {":" "_"} $bus_inf_name]
## set clock_inf_name [format "%s%s" $bus_inf_name_clean "_signal_clock"]
## set clock_inf [ipx::add_bus_interface $clock_inf_name [ipx::current_core]]
## set_property abstraction_type_vlnv "xilinx.com:signal:clock_rtl:1.0" $clock_inf
## set_property bus_type_vlnv "xilinx.com:signal:clock:1.0" $clock_inf
## set_property display_name $clock_inf_name $clock_inf
## set clock_map [ipx::add_port_map "CLK" $clock_inf]
## set_property physical_name $clock_signal_name $clock_map
## set assoc_busif [ipx::add_bus_parameter "ASSOCIATED_BUSIF" $clock_inf]
## set_property value $bus_inf_name $assoc_busif
## if { $reset_signal_name != "" } {
## set assoc_reset [ipx::add_bus_parameter "ASSOCIATED_RESET" $clock_inf]
## set_property value $reset_signal_name $assoc_reset
## set reset_inf_name [format "%s%s" $bus_inf_name_clean "_signal_reset"]
## set reset_inf [ipx::add_bus_interface $reset_inf_name [ipx::current_core]]
## set_property abstraction_type_vlnv "xilinx.com:signal:reset_rtl:1.0" $reset_inf
## set_property bus_type_vlnv "xilinx.com:signal:reset:1.0" $reset_inf
## set_property display_name $reset_inf_name $reset_inf
## set_property interface_mode $reset_signal_mode $reset_inf
## set reset_map [ipx::add_port_map "RST" $reset_inf]
## set_property physical_name $reset_signal_name $reset_map
## set reset_polarity [ipx::add_bus_parameter "POLARITY" $reset_inf]
## set_property value "ACTIVE_LOW" $reset_polarity
## proc adi_ip_add_core_dependencies {vlnvs} {
## foreach file_group [ipx::get_file_groups * -of_objects [ipx::current_core]] {
## foreach vlnv $vlnvs {
## ipx::add_subcore $vlnv $file_group
## proc adi_if_define {name} {
## ipx::create_abstraction_definition ADI user ${name}_rtl 1.0
## ipx::create_bus_definition ADI user $name 1.0
## set_property xml_file_name ${name}_rtl.xml [ipx::current_busabs]
## set_property xml_file_name ${name}.xml [ipx::current_busdef]
## set_property bus_type_vlnv ADI:user:${name}:1.0 [ipx::current_busabs]
## ipx::save_abstraction_definition [ipx::current_busabs]
## ipx::save_bus_definition [ipx::current_busdef]
## proc adi_if_ports {dir width name {type none}} {
## ipx::add_bus_abstraction_port $name [ipx::current_busabs]
## set m_intf [ipx::get_bus_abstraction_ports $name -of_objects [ipx::current_busabs]]
## set_property master_presence required $m_intf
## set_property slave_presence required $m_intf
## set_property master_width $width $m_intf
## set_property slave_width $width $m_intf
## set m_dir "in"
## set s_dir "out"
## if {$dir eq "output"} {
## set m_dir "out"
## set s_dir "in"
## set_property master_direction $m_dir $m_intf
## set_property slave_direction $s_dir $m_intf
## if {$type ne "none"} {
## set_property is_${type} true $m_intf
## proc adi_if_infer_bus {if_name mode name maps} {
## ipx::add_bus_interface $name [ipx::current_core]
## set m_bus_if [ipx::get_bus_interfaces $name -of_objects [ipx::current_core]]
## set_property abstraction_type_vlnv ${if_name}_rtl:1.0 $m_bus_if
## set_property bus_type_vlnv ${if_name}:1.0 $m_bus_if
## set_property interface_mode $mode $m_bus_if
## foreach map $maps {
## set m_maps [regexp -all -inline {\S+} $map]
## lassign $m_maps p_name p_map
## ipx::add_port_map $p_name $m_bus_if
## set_property physical_name $p_map [ipx::get_port_maps $p_name -of_objects $m_bus_if]
# adi_ip_create axi_adxcvr
INFO: [ProjectBase 1-489] The host OS only allows 260 characters in a normal path. The project is stored in a path with more than 80 characters. If you experience issues with IP, Block Designs, or files not being found, please consider moving the project to a location with a shorter path. Alternately consider using the OS subst command to map part of the path to a drive letter.
Current project path is 'C:/Users/hjang/Documents/Xilinx/ADI/hdl-hdl_2016_r2/hdl-hdl_2016_r2/library/xilinx/axi_adxcvr'
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1704] No user IP repositories specified
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository 'C:/Xilinx/Vivado/2016.2/data/ip'.
INFO: [IP_Flow 19-1700] Loaded user IP repository 'c:/Users/hjang/Documents/Xilinx/ADI/hdl-hdl_2016_r2/hdl-hdl_2016_r2/library'.
INFO: [IP_Flow 19-3656] If you move the project, the path for repository 'c:/Users/hjang/Documents/Xilinx/ADI/hdl-hdl_2016_r2/hdl-hdl_2016_r2/library' may become invalid. A better location for the repostory would be in a path adjacent to the project. (Current project location is 'c:/Users/hjang/Documents/Xilinx/ADI/hdl-hdl_2016_r2/hdl-hdl_2016_r2/library/xilinx/axi_adxcvr'.)
# adi_ip_files axi_adxcvr [list \
# "$ad_hdl_dir/library/common/up_axi.v" \
# "axi_adxcvr_es.v" \
# "axi_adxcvr_up.v" \
# "axi_adxcvr_mdrp.v" \
# "axi_adxcvr_mstatus.v" \
# "axi_adxcvr.v" ]
# adi_ip_properties_lite axi_adxcvr
INFO: [IP_Flow 19-459] IP file 'C:/Users/hjang/Documents/Xilinx/ADI/hdl-hdl_2016_r2/hdl-hdl_2016_r2/library/common/up_axi.v' appears to be outside of the project area 'C:/Users/hjang/Documents/Xilinx/ADI/hdl-hdl_2016_r2/hdl-hdl_2016_r2/library/xilinx/axi_adxcvr'. You can use the ipx::package_project -import_files option to copy remote files into the IP directory.
INFO: [IP_Flow 19-2228] Inferred bus interface 'm_axi' of definition 'ADI:user:if_xcvr_cm:1.0'.
INFO: [IP_Flow 19-2228] Inferred bus interface 's_axi' of definition 'ADI:user:if_xcvr_cm:1.0'.
INFO: [IP_Flow 19-2999] Will not infer bus interface "m_axi" for "xilinx.com:interface:aximm:1.0". The interface exists with different type "ADI:user:if_xcvr_cm:1.0".
INFO: [IP_Flow 19-2999] Will not infer bus interface "s_axi" for "xilinx.com:interface:aximm:1.0". The interface exists with different type "ADI:user:if_xcvr_cm:1.0".
INFO: [IP_Flow 19-4753] Inferred signal 'reset' from port 'axi_aresetn' as interface 'axi_aresetn'.
INFO: [IP_Flow 19-4728] Bus Interface 'axi_aresetn': Added interface parameter 'POLARITY' with value 'ACTIVE_LOW'.
INFO: [IP_Flow 19-4753] Inferred signal 'reset' from port 'up_pll_rst' as interface 'up_pll_rst'.
INFO: [IP_Flow 19-4753] Inferred signal 'clock' from port 'axi_clk' as interface 'axi_clk'.
INFO: [IP_Flow 19-4728] Bus Interface 'axi_clk': Added interface parameter 'ASSOCIATED_RESET' with value 'axi_aresetn'.
# ipx::remove_all_bus_interface [ipx::current_core]
# set_property driver_value 0 [ipx::get_ports -filter "direction==in" -of_objects [ipx::current_core]]
# s_axi_awvalid \
# s_axi_awaddr \
# s_axi_awprot \
# s_axi_awready \
# s_axi_wvalid \
# s_axi_wdata \
# s_axi_wstrb \
# s_axi_wready \
# s_axi_bvalid \
# s_axi_bresp \
# s_axi_bready \
# s_axi_arvalid \
# s_axi_araddr \
# s_axi_arprot \
# s_axi_arready \
# s_axi_rvalid \
# s_axi_rdata \
# s_axi_rresp \
# s_axi_rready} \
# m_axi_awvalid \
# m_axi_awaddr \
# m_axi_awprot \
# m_axi_awready \
# m_axi_wvalid \
# m_axi_wdata \
# m_axi_wstrb \
# m_axi_wready \
# m_axi_bvalid \
# m_axi_bresp \
# m_axi_bready \
# m_axi_arvalid \
# m_axi_araddr \
# m_axi_arprot \
# m_axi_arready \
# m_axi_rvalid \
# m_axi_rdata \
# m_axi_rresp \
# m_axi_rready} \
# ipx::infer_bus_interface axi_clk xilinx.com:signal:clock_rtl:1.0 [ipx::current_core]
INFO: [IP_Flow 19-4728] Bus Interface 'axi_clk': Added interface parameter 'ASSOCIATED_BUSIF' with value 's_axi:m_axi'.
# ipx::infer_bus_interface axi_aresetn xilinx.com:signal:reset_rtl:1.0 [ipx::current_core]
# ipx::add_bus_parameter ASSOCIATED_BUSIF [ipx::get_bus_interfaces axi_clk \
# set_property value s_axi:m_axi [ipx::get_bus_parameters ASSOCIATED_BUSIF \
# -of_objects [ipx::get_bus_interfaces axi_clk \
# set_property range {4096} [ipx::get_address_blocks axi_lite \
# for {set n 0} {$n < 16} {incr n} {
# if {($n%4) == 0} {
# adi_if_infer_bus ADI:user:if_xcvr_cm master up_cm_${n} [list \
# "sel up_cm_sel_${n} "\
# "enb up_cm_enb_${n} "\
# "addr up_cm_addr_${n} "\
# "wr up_cm_wr_${n} "\
# "wdata up_cm_wdata_${n} "\
# "rdata up_cm_rdata_${n} "\
# "ready up_cm_ready_${n} "]
# adi_if_infer_bus ADI:user:if_xcvr_cm master up_es_${n} [list \
# "sel up_es_sel_${n} "\
# "enb up_es_enb_${n} "\
# "addr up_es_addr_${n} "\
# "wr up_es_wr_${n} "\
# "wdata up_es_wdata_${n} "\
# "rdata up_es_rdata_${n} "\
# "ready up_es_ready_${n} "]
# adi_if_infer_bus ADI:user:if_xcvr_ch master up_ch_${n} [list \
# "pll_locked up_ch_pll_locked_${n} "\
# "rst up_ch_rst_${n} "\
# "user_ready up_ch_user_ready_${n} "\
# "rst_done up_ch_rst_done_${n} "\
# "lpm_dfe_n up_ch_lpm_dfe_n_${n} "\
# "rate up_ch_rate_${n} "\
# "sys_clk_sel up_ch_sys_clk_sel_${n} "\
# "out_clk_sel up_ch_out_clk_sel_${n} "\
# "sel up_ch_sel_${n} "\
# "enb up_ch_enb_${n} "\
# "addr up_ch_addr_${n} "\
# "wr up_ch_wr_${n} "\
# "wdata up_ch_wdata_${n} "\
# "rdata up_ch_rdata_${n} "\
# "ready up_ch_ready_${n} "]
