output short break after frequency updated
Question asked by william2016 on Jan 6, 2017
Latest reply on Jan 8, 2017 by william2016
Hello All,
I have a problem to keep the signal continuous after frequency changed. Please check the image attached.signal break after freq changed
I am doing frequency sweeping, i.e.scanning a short range of frequency and measure some parameters.
The problem is when the frequency is changed, there is a short break of output.
Even I switching freq register doesn't help at all.
Here is the code only using one freq register:
word=(unsigned int)(0x2100); //control register
SendWordDDS(word);
t=fv;
t=t&0x00003fff; //last 14bits
word=(unsigned int)(0x4000+(t)); //14bit LSBs + 01(the first two bits) 01means freq0
SendWordDDS(word);
t=fv;
t=t&0x0fffc000; //from 15 to 28 bits
word=(unsigned int)(0x4000+(t>>=14)); //14bit HSBs + 01(the first two bits)
SendWordDDS(word);
word=(unsigned int)(0xc000); //phase register 0
SendWordDDS(word);
word=(unsigned int)(0x2000); //exit reset
SendWordDDS(word);
I know it is not a good way to only use one freq register, which has been noted in datasheet.
I changed the code to switch freq register, but doesn't help.
Please give a little instructions.
Can you provide a sample code to do freq sweeping?
Thanks
The routine to send freq is:
unsigned int word;
unsigned long int t;
if(!IsDDSinitialized)
{//only reset the register at first setting of freq
SendWordDDS(word);
else
if(CurrentFreqReg==0) word=(unsigned int)(0x2000); //control register, no reset
else word=(unsigned int)(0x2000); //control register, no reset
SendWordDDS(word);
t=fv;
if(CurrentFreqReg==0) word=(unsigned int)(0x4000+(t)); //14bit LSBs + 01(the first two bits) 01means freq0
else word=(unsigned int)(0x8000+(t)); //14bit LSBs + 10(the first two bits) 10means freq1
SendWordDDS(word);
t=fv;
if(CurrentFreqReg==0) word=(unsigned int)(0x4000+(t>>=14)); //14bit HSBs + 01(the first two bits)
else word=(unsigned int)(0x8000+(t>>=14)); //14bit HSBs + 10(the first two bits)10means freq1
SendWordDDS(word);
SendWordDDS(word);
//finally apply setting, output updated
if(CurrentFreqReg==0) word=(unsigned int)(0x2000); //exit reset
else word=(unsigned int)(0x2800); //exit reset, freq1
SendWordDDS(word);
//update the freq bank
if(CurrentFreqReg==0)CurrentFreqReg=1;
else CurrentFreqReg=0;
IsDDSinitialized=0;
