Can someone update the console_get_command() function?
Question asked by kivircik_ali on Jan 4, 2017
Latest reply on Jan 4, 2017 by DragosB
Can someone update the console_get_command() function in No-OS drivers as follows? It;
1. sends back the characters that are received from the serial port
2. perceives backspace key and takes necessary precautions.
I have tested and verified the function with different serial port programs.
void console_get_command(char* command)
   char received_char = 0;
   unsigned char char_number = 0;
   while(1)
      if (char_number == 0) {
         console_print("-> ");
      received_char = XUartPs_RecvByte(STDIN_BASEADDRESS);
      if ((received_char == 127) || (received_char == 8)) { //check if backspace key pressed, the received value depends on the serial port program you used
         command[char_number--] = ';
      } else {
         command[char_number++] = received_char;
      XUartPs_SendByte(STDIN_BASEADDRESS, received_char); //send back what is written
      if ((received_char == '\n') || (received_char == '\r')) {
         if (char_number > 1) {
            break;
         } else {
            char_number = 0;
