ADSP-SC589: Buildroot build fails as dhcpcd does not build
Question asked by pj0585 on Jan 3, 2017
Latest reply on Nov 13, 2017 by GrahamNewton
I'm trying to build my rootfs from buildroot for my SC589 EZ BRD. I was able to build using default configurations. However, when I modify buildroot to add more packages then build fails when compiling dhcpcd package. Below are the details:
>>> dhcpcd 6.6.7 Building
PATH="/WORK/build-repo/sc58x-dev/buildroot/output/host/bin:/WORK/build-repo/sc58x-dev/buildroot/output/host/sbin:/WORK/build-repo/sc58x-dev/buildroot/output/host/usr/bin:/WORK/build-repo/sc58x-dev/buildroot/output/host/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/opt/analog/cces-linux-add-in/1.1.0/ARM/arm-linux-gnueabi/bin:/opt/analog/cces/2.3.0/ARM/arm-none-eabi/bin" /usr/bin/make -j1 -C /WORK/build-repo/sc58x-dev/buildroot/output/build/dhcpcd-6.6.7 all
make[1]: Entering directory `/WORK/build-repo/sc58x-dev/buildroot/output/build/dhcpcd-6.6.7'
/WORK/build-repo/sc58x-dev/buildroot/output/host/usr/bin/arm-linux-gnueabi-gcc  -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Os  -std=c99  -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_BSD_SOURCE -D_XOPEN_SOURCE=700 -D_DEFAULT_SOURCE -DINET -DINET6 -I./crypt -c dhcpcd.c -o dhcpcd.o
In file included from /WORK/build-repo/sc58x-dev/buildroot/output/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/sys/socket.h:38:0,
                 from dhcpcd.c:33:
ipv6.h:154:41: error: invalid application of ‘sizeof’ to incomplete type ‘struct in6_pktinfo’
  unsigned char sndbuf[CMSG_SPACE(sizeof(struct in6_pktinfo))];
ipv6.h:146:38: error: invalid application of ‘sizeof’ to incomplete type ‘struct in6_pktinfo’
 #define IP6BUFLEN (CMSG_SPACE(sizeof(struct in6_pktinfo)) + \
ipv6.h:157:23: note: in expansion of macro ‘IP6BUFLEN’
  unsigned char rcvbuf[IP6BUFLEN];
make[1]: *** [dhcpcd.o] Error 1
make[1]: Leaving directory `/WORK/build-repo/sc58x-dev/buildroot/output/build/dhcpcd-6.6.7'
struct in6_pktinfo is defined in linux/ipv6.h  (output/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/linux/ipv6.h) and that seems to be included in ipv6.h if "-D__linux__ && -D__GLIBC__" are used. I tried including both in config.mk but the error persists.
Any inputs on how to fix this?
Regards, Pj
