Tx Rx Signal chain control
Question asked by Abhisheknaik on Jan 1, 2017
Latest reply on Jan 4, 2017 by sripad
             In Ad9371.... There are four pins TXx_ENABLE and RXx_ENABLE to control Tx and Rx signal chains... Master( ZYNQ in my case ) has to pull appropriate pins high to switch between Rx and Tx paths... Am I right???
Or does Ad9371 has intelligence to switch between the paths (Tx and Rx) depending upon the data it receives from ZYNQ?
            When I was going through AD9371 UG doc I came across paired gpios (19 low voltage gpio).. somebody please explain me what it is?
           In windows TES... gpio tab i absorb that even if pin no. 16 is not used.. It is configured as input pin. Why? Is it a bug? or That pin is always input even if we do not use it.. How to make it output pin?
Thank you,
 Abhishek Naik..
