requesting information to selection of accelerometer sensor
Question asked by prashanth@@ on Dec 30, 2016
Latest reply on Dec 30, 2016 by NevadaMark
good morning,  I am doing research on blast-induced ground vibration monitoring in mines.so I need a suggestion from you to select good accelerometer sensor which can measure the ground vibration. so here my queries 1.please can you suggest a good accelerometer sensor(3-axis) to measure ground vibration induced by blasting 2.the frequencies of ground vibrations are in between DC to 100Hz 3.the magnitude of ground vibration waves are very like 0.1mm/s to 50mm/s 4.high sensitivity and low noise accelerometer sensor should be used. please follow the specification and suggest good accelerometer
