Problem building the reference design no-os software
Question asked by nerdler33 on Dec 27, 2016
Latest reply on Dec 30, 2016 by rejeesh
I successfully created the vivado project and exported the hdf file. When I tried running the "create_xilinx_sdk_project.bat" The command prompt crashed and in the designated folder, an error log that contained: "A fatal error has been detected by the Java Runtime Environment:" and many memory locations and heap information that I can provide if needed. I also tried to create the sdk project myself and copy the required source files over, as shown by this tutorial Xilinx SDK Software setup [Analog Devices Wiki]  . I opened the sdk and attempted to create an application project using a custom hardware platform created from the exported hdf from vivado. The following errors were present before the source files were included:
Description Resource Path Location Type
make: Target `all' not remade because of errors. bsp C/C++ Problem
make[1]: *** [xdevcfg_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xdevcfg_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/devcfg_v3_4/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xdmaps.o] Error 2 bsp C/C++ Problem
make[1]: *** [xdevcfg.o] Error 2 bsp C/C++ Problem
make[1]: *** [xdevcfg_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xdevcfg_hw.o] Error 2 bsp C/C++ Problem
make[1]: *** [xdevcfg_intr.o] Error 2 bsp C/C++ Problem
make[1]: Target `libs' not remade because of errors. bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/coresightps_dcc_v1_2/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xddrps_libs] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/ddrps_v1_0/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [libs] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/axivdma_v6_1/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xcoresightpsdcc.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/emacps_v3_2/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xgpiops.o] Error 2 bsp C/C++ Problem
make[1]: *** [xgpiops_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xgpiops_hw.o] Error 2 bsp C/C++ Problem
make[1]: *** [xemacps_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xemacps_hw.o] Error 2 bsp C/C++ Problem
make[1]: *** [xemacps_intr.o] Error 2 bsp C/C++ Problem
make[1]: *** [xemacps_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/dmaps_v2_1/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xemacps.o] Error 2 bsp C/C++ Problem
make[1]: *** [xemacps_bdring.o] Error 2 bsp C/C++ Problem
make[1]: *** [xemacps_control.o] Error 2 bsp C/C++ Problem
make[1]: *** [xdmaps_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xdmaps_hw.o] Error 2 bsp C/C++ Problem
make[1]: *** [xdmaps_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xdmaps_sinit.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscugic.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscugic_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscugic_hw.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscugic_intr.o] Error 2 bsp C/C++ Problem
make[1]: *** [xqspips_options.o] Error 2 bsp C/C++ Problem
make[1]: *** [xqspips_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xqspips_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/qspips_v3_3/src/make.libs] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/iic_v3_2/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xqspips.o] Error 2 bsp C/C++ Problem
make[1]: *** [xqspips_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xqspips_hw.o] Error 2 bsp C/C++ Problem
make[1]: *** [xgpiops_intr.o] Error 2 bsp C/C++ Problem
make[1]: *** [xgpiops_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xgpiops_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/gpiops_v3_1/src/make.libs] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/scuwdt_v2_1/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xsdps.o] Error 2 bsp C/C++ Problem
make[1]: *** [xsdps_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xsdps_options.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscuwdt.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscuwdt_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscuwdt_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscuwdt_sinit.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscutimer_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscutimer_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscutimer_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/scutimer_v2_1/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xscugic_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xscugic_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/scugic_v3_3/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xscutimer.o] Error 2 bsp C/C++ Problem
make[1]: *** [xuartps_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xuartps_hw.o] Error 2 bsp C/C++ Problem
make[1]: *** [xuartps_intr.o] Error 2 bsp C/C++ Problem
make[1]: *** [xuartps_options.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/spips_v3_0/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [standalone_libs] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/standalone_v5_5/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xuartps.o] Error 2 bsp C/C++ Problem
make[1]: *** [xspips_hw.o] Error 2 bsp C/C++ Problem
make[1]: *** [xspips_options.o] Error 2 bsp C/C++ Problem
make[1]: *** [xspips_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xspips_sinit.o] Error 2 bsp C/C++ Problem
make[1]: *** [xsdps_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/sdps_v2_8/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xspips.o] Error 2 bsp C/C++ Problem
make[1]: *** [xspips_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xadcps_intr.o] Error 2 bsp C/C++ Problem
make[1]: *** [xadcps_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xadcps_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/xadcps_v2_2/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xusbps_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/usbps_v2_4/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xadcps.o] Error 2 bsp C/C++ Problem
make[1]: *** [xadcps_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xusbps_endpoint.o] Error 2 bsp C/C++ Problem
make[1]: *** [xusbps_g.o] Error 2 bsp C/C++ Problem
make[1]: *** [xusbps_hw.o] Error 2 bsp C/C++ Problem
make[1]: *** [xusbps_intr.o] Error 2 bsp C/C++ Problem
make[1]: *** [xuartps_selftest.o] Error 2 bsp C/C++ Problem
make[1]: *** [xuartps_sinit.o] Error 2 bsp C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/uartps_v3_1/src/make.libs] Error 2 bsp C/C++ Problem
make[1]: *** [xusbps.o] Error 2 bsp C/C++ Problem
As I have exported and created software several times before without encountering this error, I was wondering if anymore more experienced than I could shed some light on what is going on. All I have done so far is build the vivado project and attempted to transfer to the sdk. I am using vivado and sdk versions 2015.2 with the appropriate version of the reference design from the git repository. Let me know if there is anything else you need.
Thank you for your time.
