ADV7604 EVB DSUB RGB 1080P@60Hz settings
Question asked by Sam.S on Dec 13, 2016
Latest reply on Mar 20, 2017 by edo
Dear Sir,
Due to our customer have to use auto graphic mode to handle all of RGB timing, and I have try below settings in ADV7404 EVB,
but the screen can't show the RGB D-Sub (separate sync) source input, and through by HDMI signal from EVB of ADV7511.
The register settings I have tried as below:
topwin.OnReset()
writeReg(0x40, 0x0B, 0x44) # Power down ESDP block
writeReg(0x50, 0x20, 0x1F) # De-assert HDP
writeReg(0x50, 0x20, 0x0F) # Insert HDP
writeReg(0x40, 0x0C, 0x40) # Power up CP core
writeReg(0x40, 0x02, 0xF4) # OP_RANGE Enable
writeReg(0x40, 0xF6, 0xC8) # ESDP Address to C8
writeReg(0x40, 0xF7, 0x66) # DPP Address to 66
writeReg(0x40, 0xFE, 0x60) # VDP Address to 60
writeReg(0x40, 0x15, 0x90) # Disable Tristate of Pins except for Audio pins
writeReg(0x40, 0x00, 0x07) # VID_STD = 0x0C XGA60Hz #RGB Auto Graphic Mode
writeReg(0x40, 0x01, 0x02) # Pri_Mode = RGB Graphic Mode
writeReg(0x40, 0x16, 0xC8) # PLL settings 1, 148.5M/67500=2200=0x898
writeReg(0x40, 0x17, 0x98) # PLL settings 2, 148.5M/67500=2200=0x898
writeReg(0x44, 0x8F, 0x01) # FR_LL setting 1, 28.636363M/67500=424=0x1A8
writeReg(0x44, 0x90, 0xA8) # FR_LL setting 2, 28.636363M/67500=424=0x1A8
writeReg(0x44, 0xAB, 0x46) # LCOUNT_MAX setting 1, LCF=0x464
writeReg(0x44, 0xAC, 0x40) # LCOUNT_MAX setting 2, LCF=0x464
writeReg(0x44, 0x91, 0x10) # INTERLACED setting
writeReg(0x44, 0x8B, 0x4F) #
writeReg(0x44, 0x8C, 0xC8) # DE H END
writeReg(0x44, 0x8D, 0x00) # DE H START
writeReg(0x40, 0x02, 0xF2) # RGB color space
writeReg(0x40, 0x03, 0x42) # 36-bit 4:4:4 SDR mode 0
writeReg(0x40, 0x05, 0x28) # Disable AV Codes, enable Free-Run, Sync output setting
writeReg(0x40, 0x06, 0xC5) # Sync polirity setting
writeReg(0x40, 0x07, 0x54) # Sync CH1 H/V sync select
writeReg(0x4C, 0x13, 0x84) # Enable the DLL on LLC (BIT[7]), and set LLC_DLL_Phase 5 bits
writeReg(0x40, 0x33, 0x40) # Muxes the DLL output on the LLC output pin (BIT[6])
writeReg(0x4C, 0x00, 0x08) # Power up ADC 0/1/2
writeReg(0x4C, 0x01, 0x06) # Power up input Mux
writeReg(0x4C, 0x02, 0x02) # ADC SW auto and Sync Select auto
writeReg(0x4C, 0x03, 0x78) # ADC 0/1 SW manual
writeReg(0x4C, 0x04, 0x90) # ADC 2/3 SW manual
writeReg(0x4C, 0x12, 0xFB) # ADC noise shaping filter controls
writeReg(0x4C, 0x13, 0x88) # LLC DLL Phase Enable, and set phase value
writeReg(0x4C, 0x0C, 0x0D) # CP core Gain controls
writeReg(0x4C, 0xA0, 0x00) # Controls for the clock divider that precedes the Video DPLL
writeReg(0x4C, 0x15, 0x00) # Sync 1/2 input selec, and no sync filter
writeReg(0x4C, 0xC8, 0x00) # phase control
writeReg(0x44, 0x85, 0x0B) # Using SSPD CH1 results, Sync Ch1 setting as separate H/V sync
writeReg(0x44, 0x3E, 0x00) # CP core pre-gain control
writeReg(0x44, 0x40, 0x80) # CP core pre-gain control
writeReg(0x44, 0x7C, 0xC0) # Polarity control for all synchronization signals output by the CP core
writeReg(0x44, 0xC3, 0x39) # CP coast control
writeReg(0x44, 0xCF, 0x00) # Macrovision controls
writeReg(0x60, 0x98, 0x88) # VDP filter adaptive slicer controls
writeReg(0x60, 0x9A, 0x00) # VDP Filter controls
writeReg(0x60, 0x9B, 0x05) # VDP filter adaptive controls
writeReg(0x60, 0x9D, 0x02) # VDP slice correction control for non standard input
writeReg(0x4C, 0xC4, 0x00) # LLC DLL Normal
writeReg(0x4C, 0x12, 0x7B) # ADI Recommended Initialization for ADCs
writeReg(0x4C, 0x0C, 0x1F) # ADI Recommended Initialization for ADCs
writeReg(0x44, 0x3E, 0x04) # ADI Recommended Initialization for ADCs
writeReg(0x44, 0xC3, 0x39) # ADI Recommendation (default value) for Graphic Mode
writeReg(0x44, 0x40, 0x5C) # ADI Recommendation (default value) for Graphic Mode
writeReg(0x44, 0x81, 0xC0)
writeReg(0x44, 0x6C, 0x10) # clamp setting 1
writeReg(0x44, 0x40, 0x5C) # gain adj
writeReg(0x44, 0xC5, 0x91) # clamp setting 2
writeReg(0x44, 0x77, 0xFF) # offset setting 1
writeReg(0x44, 0x78, 0xFF) # offset setting 2
writeReg(0x44, 0x79, 0xFF) # offset setting 3
writeReg(0x44, 0x7A, 0xFF) # offset setting 4
writeReg(0x44, 0x73, 0xF1) # gain setting 1
writeReg(0x44, 0x74, 0xCC) # gain setting 2
writeReg(0x44, 0x75, 0x6B) # gain setting 3
writeReg(0x44, 0x76, 0x1B) # gain setting 4
writeReg(0x40, 0x15, 0x00) # Enable all outputs pins
writeReg(0x50, 0x19, 0x01) # FPGA ADV7604
writeReg(0x50, 0x10, 0x05) # FPGA MUX to enable 36 bit
writeReg(0x50, 0x20, 0x0F) # FPGA HPD All Ports
writeReg(0x72, 0x01, 0x00) # Set 'N' value at 6144
writeReg(0x72, 0x02, 0x18) # Set 'N' value at 6144
writeReg(0x72, 0x03, 0x00) # Set 'N' value at 6144
writeReg(0x72, 0x15, 0x00) # 24-bit, 444 YPrPb input
writeReg(0x72, 0x16, 0x60) # YPrPb 444
writeReg(0x72, 0x18, 0x46) # Disable CSC
writeReg(0x72, 0x30, 0x16) # Hsync Placement_1 (Embedded Sync)
writeReg(0x72, 0x31, 0x02) # Hsync Placement_2 and Hsync Duration_1
writeReg(0x72, 0x32, 0xC0) # Hsync Duration_2 and Vsync Placement_1
writeReg(0x72, 0x33, 0x10) # Vsync Placement_2 and Vsync Duration_1
writeReg(0x72, 0x34, 0x05) # Vsync Duration_2
writeReg(0x72, 0x35, 0x2F) # Hsync delay1 (DE Generator)
writeReg(0x72, 0x36, 0xE9) # Hsync delay2 and Vsync delay
writeReg(0x72, 0x37, 0x0F) # Interlace offset and Active Width
writeReg(0x72, 0x38, 0x00) # Active Width
writeReg(0x72, 0x39, 0x43) # Active Height1
writeReg(0x72, 0x3A, 0x80) # Active Height2
writeReg(0x72, 0xD7, 0x16) # Hsync Placement_1 (Sync Adjustment)
writeReg(0x72, 0xD8, 0x02) # Hsync Placement_2 and Hsync Duration_1
writeReg(0x72, 0xD9, 0xC0) # Hsync Duration_2 and Vsync Placement_1
writeReg(0x72, 0xDA, 0x10) # Vsync Placement_2 and Vsync Duration_1
writeReg(0x72, 0xDB, 0x05) # Vsync Duration_2
writeReg(0x72, 0x17, 0x01) # DE Generator Enable
writeReg(0x72, 0x40, 0x80) # General control packet enable
writeReg(0x72, 0x41, 0x10) # Power down control
writeReg(0x72, 0x48, 0x48) # Video input bus reversed, Video input right justified
writeReg(0x72, 0x49, 0xA8) # Set dither mode - 12-to-10 bit
writeReg(0x72, 0x4C, 0x06) # Set 12 bit output
writeReg(0x72, 0x96, 0x20) # HPD interrupt clear
writeReg(0x72, 0x55, 0x00) # Set RGB 444 in AVI infoframe
writeReg(0x72, 0x56, 0x08) # Set active format aspect
writeReg(0x72, 0x98, 0x03) # ADI recommended write
writeReg(0x72, 0x99, 0x02) # ADI recommended write - lock count limit
writeReg(0x72, 0x9C, 0x30) # PLL filter R1 value
writeReg(0x72, 0x9D, 0x61) # Set clock divide
writeReg(0x72, 0xA2, 0xA4) # ADI recommended write
writeReg(0x72, 0xA3, 0xA4) # ADI recommended write
writeReg(0x72, 0xAF, 0x16) # Select HDMI mode
writeReg(0x72, 0xBA, 0xC0) # Set TX Clock Delay
writeReg(0x72, 0xDE, 0x9C) # ADI recommended write
writeReg(0x72, 0xE4, 0x60) # VCO_Swing_Reference_Voltage
writeReg(0x72, 0xFA, 0x7D) # Nbr of times to look for good phase
writeReg(0x50, 0x20, 0x00) # HPD
topwin.ReadCurrentInterface()
And I found a issue that the RGB signal 1080P 60Hz waveform of DE_Vertical from ADV7604 as below:
(The DE_VERTICAL_START position (V back_porch) is too short)
RGB_1080P60_DE_Vertical
I try to adjust the ADV7604 DE_V_START[3:0] register in CP Map, Address 0x8E[7:4],
the minimux DE_V_START position I can adjust as below waveform:
ADV7604_RGB_1080P60_DE_Vertical_Minimux
the maxmux DE_V_START position I can adjust as below waveform:
ADV7604_RGB_1080P60_DE_Vertical_Maxmum
But compare with HDMI input signal source signal(can normal display), the DE_Vertical waveform as below:
HDMI_DE_Vertical_Normal Display
I can not try to set the RGB timing (using auto graphic mode settings) V back_porch same as the HDMI input source any more.
I don't know what is the reason why D-Sub RGB signal can't display through ADV7511 output to HDMI display.
Is due to the DE_Vertical_Start position? Or others reason such as I found another issue:
The DE_Horizontal and Hsync have about 35ns jitter as I attached files(settings the registers in auto graphic).
I also have checked related register such as ADV7604 FREE RUN status in CP map 0xFF BIT[4] (CP_FREE_RUN='0')
And ADV7511 PLL Lock Status in Main map 0x9E BIT[4] (PLL Lock Status='1'), it's seem the settings should be fine except
the DE_V_START position and the DE / Hsync jitter I mentioned above.
Even I have set the internal DE generation of ADV7511, but it still no useful.
Would you please kindly provide any advised for this issue?
Thank you very much!
Sam
