HMC365G8 - Compensation With No Input Signal & Single ended output
Question asked by dkaraca on Nov 23, 2016
Latest reply on Nov 28, 2016 by huangzeyan
My question is about HMC365G8 freq. divider.
In the application note "Frequency Divider Operation & Compensation With No Input Signal", it is written that a resistor must be connected from one of the input pins to the ground in order to prevent signal generation at the output in the absence of input signal. The required resistor values are given for several freq. divider components, but not for HMC365G8. What would be a suitable resistor value for this component?
Second, if I want to use this component as a single ended element, how should I terminate the second output port? Can you please explain clearly?
Thanks in advance.
Best,
Denizhan
