convert float to integer
Question asked by macci77 on Nov 22, 2016
Latest reply on Nov 30, 2016 by nithya.koch
My project is based on the TalkThrough example acquiring data with the adc1979 and sent out with the dac 1962a. I am using the SC584 Sharc
The process of the project uses floating point values.
a - in what format is the incoming data? integer/fract ?
b - What function (optimized timewise) to convert to float 32 bit should I use?
c - For sending out via the DAC what conversion function from float to integer/fract should I use?
Thanks
Maccabi
