ADFMCOMMS-1 ZedBoard Reference Design DMA Configuration
Question asked by a55moham on Nov 21, 2016
Latest reply on Nov 25, 2016 by a55moham
Branched from an earlier discussion
I used this technique of submit and wait but I found the data is not continuous, so I added in the beginning of the wait function:
do {
adc_dma_read(AXI_DMAC_REG_IRQ_PENDING, &reg_val);
while(reg_val != (AXI_DMAC_IRQ_SOT | AXI_DMAC_IRQ_EOT));
adc_dma_write(AXI_DMAC_REG_IRQ_PENDING, reg_val);
which is part of the latest code of adc_capture. Then I did the following call:
buffer_transfer_id[0] = adc_capture_submit(captureSize, buffer_addr[0]);
buffer_transfer_id[1] = adc_capture_submit(captureSize, buffer_addr[1]);
adc_capture_wait(buffer_transfer_id[0]);
adc_capture_wait(buffer_transfer_id[1]);
The code is stuck in the second call of adc_capture_wait in the do-while loop I added above, so I changed the condition to be:
do {
while((reg_val & AXI_DMAC_IRQ_EOT) != ( AXI_DMAC_IRQ_EOT));
And it worked fine for up to 3 calls of submit and wait but when I do 4 like the following:
buffer_transfer_id[2] = adc_capture_submit(captureSize, buffer_addr[2]);
buffer_transfer_id[3] = adc_capture_submit(captureSize, buffer_addr[3]);
adc_capture_wait(buffer_transfer_id[2]);
adc_capture_wait(buffer_transfer_id[3]);
it stuck again in the last call of "adc_capture_wait" in the same while loop because reg_val is expected to be 2 and it is zeros.
Could you help me in identifying the problem and how to solve it. I do not want to use interrupts because I want to process data in buffer while I am receiving the second (ping pong).
Ahmed
