ad9957 dac Interpolation mode does not work
Question asked by abc2005211 on Nov 21, 2016
Latest reply on Jan 3, 2017 by KennyG
I use the ad9957 evaluation board and successfully applied single tone mode and qduc mode of ad9957.
But when i evaluated ad9957  dac interpolation mode , it did not work.
My operation order was below:
1. write cfr1  16'h0200_0000
2. write cfr2  16'h0040_0a20
3. write cfr3 16'h1d3f_4150
4. write 0x0e reg   64'h08b5_0000_0000_0000
5. set tx enable high  with connect it to vcc.
6. set D0-d17  high or low with connect one of the to the vcc .
i watched the oscilloscope with zero output .
what is the wrong ?
/**************************************************** update*********************/
now  when a aligned the data with pdclk negedge so that  ad9957 could load the data correctly.
but i found that the pll lock could not go high. and i only changed the cfr1 from 16'h0100_000.
and when the cfr1 register was 16'h0100_0000 , the pll will locked and output correctly.
