PVP problem on BF609
Question asked by lawrence.guan@liteon.com on Nov 21, 2016
Latest reply on Jan 11, 2017 by Jithul_Janardhanan
Hi, Everybody:
I use the PVP - Convolution function on BF609 platform , it can work in ICE mode, but can't work in Flash mode. In Flash mode, gNumProcessedFrames always is 0.
while((gNumProcessedFrames < 1))
/* Wait until test frame is processed.*/
I monitor the callback function, in ICE mode , i can see PipeCallback, CONVInStreamCallback, CONVOutStreamCallback executed, but in Flash mode , i only see PipeCallback executed.
static void PipeCallback(void *pCBParam,ADI_PVP_EVENT eEvent,void *pArg)
      /* Handle the events */
      switch(eEvent)
         case ADI_PVP_EVENT_CONFIG_PROCESSED:
            LTCPrintf("G-P\n");
            break;
         default:
         /* We are not expecting any PVP pipe related events. It should be an error */
            LTCPrintf("Unexpected PVP Pipe related event");
            break;
   return;
static void CONVInStreamCallback(void *pCBParam,ADI_PVP_EVENT eEvent,void *pArg)
      /* Handle stream related events here */
      switch(eEvent)
            case ADI_PVP_EVENT_BUFFER_PROCESSED:
               //printf("CONVInStreamCallback in \n");
               LTCPrintf("G-I\n");
               break;
            default:
               break;
         return;
static void CONVOutStreamCallback(void *pCBParam,ADI_PVP_EVENT eEvent,void *pArg)
      switch(eEvent)
               /* Each test will be waiting for this event */
               LTCPrintf("G-O\n");
               gNumProcessedFrames++;
               break;
            default:
            LTCPrintf("Unexpected event received in CONV Output Stream related callback\n");
            break;
      return;
So, why use ICE download the code in BF609 platfom , PVP can work , but Flash mode can't??
Thanks.
