Using multiple channels with AD7190 ADC
Question asked by mike@frazier.in on Nov 20, 2016
Latest reply on Nov 24, 2016 by mike@frazier.in
I have a scale project where I am using Channel 1 to read the value from a strain gauge. I would like to monitor the temp sensor to compensate for temperature. I have been having problems implementing 2 sources. I have questions about:
1) When both channel 1 (AIN3 & AIN4) and channel 2 (Temp Sensor) are enabled do I need to worry about disabling the Temp Sensor to calibrate channel 1?
2) Is the correct approach to reading both values with the ADC in continuous mode (MD2- MD0 = 000) and CREAD = 0:
    a) drop CS low
             I) wait for DAT_STA to go high & low
             II) read channel 1
             III) wait for DAT_STA to go High & low
             IV) read channel 2
   b) bring CS high
3) No matter what I try I can't seem to get a data read to add the status register as the 4th word. I have set the MR20 to 1 but all I get is 255 as a return value. I can read it as a separate command and reading the 8 bit values but I can't get it to added to a 32 bit read of the data register.
Thank you for whatever help you can give me,
Mike
