Paste error when loading Hierarchy Board
Question asked by op-electronics on Nov 14, 2016
Latest reply on Nov 15, 2016 by op-electronics
i get the following error when i try to load a saved Hierarchy Board:
When i hit OK only blocks are loaded with no wiring between them. If i try to rewire the board and save it (with a different file name) i get the same paste error and no wires when board is loaded.
This apparently happened after i accidentally saved a blank project over a project i was working on. The Hierarchy Board was part of the project i was working with but was already saved as a .dspbrd file and was not even sharing the main folder with the project.
I attach the corrupted hierarchy board. If you could please check if you get the same error when loading.
Thank you
Omar
