how can i write/read two bytes to the TWI interface using ADSP21489?
Question asked by jett on Nov 9, 2016
Latest reply on Nov 23, 2016 by Jithul_Janardhanan
Hi  everyone
                I ues the TWI interface of SHARC reading the tempereture sensor.Now, i use the example of the Power_On_Self_Test  and  i can write/read one byte data to the TWI interface. But i can not  write/read two bytes to the TWI interface.
              MY slave is the tmp112,i read the datasheet, the time diagram is below.
//THE CODE
void I2C_Master_Write (unsigned int data, unsigned int address)
/* setup flag */
g_write_pend = 1;
/* write address to the 8-bit TX fifo */
*pTXTWI8 = address;
/* enable master transfer complete and TX FIFO service interrupts */
*pTWIIMASK = TWIMCOM | TWITXINT;
/* setup for 2 data bytes, master enable, master TX */
*pTWIMCTL = TWIDCNT2 | TWIMEN;
/* wait for data */
while ( g_buff_empty != 1 )
/* write data to the 8-bit TX fifo */
*pTXTWI8 = data;
/* reset flag */
g_buff_empty = 1;
/* wait for write to complete */
while( g_write_pend == 1 )
*pTXTWI8 = data;
/* reset flag */
g_buff_empty = 1;
int Read_TWI_Register(int address)
int temp; /* temporary int */
/* setup flags, to read we do both write and read */
g_write_pend = 1;
g_read_pend = 1;
*pTXTWI8 = address;
/* enable master transfer complete interrupt */
*pTWIIMASK = TWIMCOM;
/* setup for 1 data byte, master enable, master TX */
*pTWIMCTL = TWIDCNT1 | TWIMEN;
/* setup for 1 data byte, master enable, master RX */
*pTWIMCTL = TWIDCNT1 | TWIMEN | TWIMDIR;
/* wait for read to complete */
while( g_read_pend == 1 )
/* read data from the 8-bit RX fifo */
temp = *pRXTWI8;
return temp;
catching  the wave from the OSC
the write
the read
hope someone can give me some advice,thanks.
        jack
