SigmaDSP questions
Question asked by Kevin1102 on Nov 8, 2016
Latest reply on Nov 9, 2016 by DaveThib
Customer will initial project to study SigmaDSP.
Could you reply some doubt:
As attached pictures,
1. Should  we adjustment each volume and EQ  or not ?  correspond to a register can be an external MCU with I2C ?
2. If you use the external MCU to adjust the value of the register, how about the delay time or latency?
3. When using the external MCU to adjust the register value, SigmaDSP can complete the performance between 23-85 changes (EQ and volume) or not?for example, from 23 to 85
4. Use external MCU to adjust the value of the register, for example, from 23 to 85, the process will not be crack(much distortion) or not?
For example, a tone on each level of a sonic boom.
Regard,
Kevin Tsai
