BF506 UART  EDTPTI mode
Question asked by SeaWolf on Aug 26, 2011
Latest reply on Oct 17, 2011 by vinodbableshwar
Hello. I can't configure the UART0 DMA transfer using EDTPTI bit(ADSP-BF50x Processor Hardware reference rev1.0 p.15-25 ). When DMA work unit finished transmit data interrupt not generated. In normal mode,I do the following and it work correctly:
EX_INTERRUPT_HANDLER(UART_DMA_HANDLER)
    ushort regVal;
    regVal = *pDMA9_IRQ_STATUS;
    if(regVal)
        if(regVal & DMA_DONE)
            *pUART0_IER_CLEAR = ETBEI;
            *pDMA9_IRQ_STATUS |= DMA_DONE;
             while(!(*pUART0_LSR & TEMT))
                asm volatile("nop;");
void InitUART0_bf506()
     *pSIC_IMASK0  |= (1 << 23) | (1<<22);     //dma9,dma8 enable interrupt
     register_handler(ik_ivg10,UART_DMA_HANDLER);
     *pDMA9_CONFIG = FLOW_STOP | WDSIZE_8 | SYNC | DI_EN;
void WriteUART_DMA(void* buf,ushort size)
    *pDMA9_START_ADDR = buf;
    *pDMA9_X_COUNT = size;
    *pDMA9_X_MODIFY = 1;
    *pDMA9_CONFIG |= DMAEN;
    ssync();
    *pUART0_IER_SET = ETBEI;
But when I use EDTPTI my InitUART0_bf506() and WriteUART_DMA have changes
     *pDMA9_CONFIG = FLOW_STOP | WDSIZE_8 | SYNC;    // ! No DI_EN, because TEMT event triggers a DMA interrupt after the DMA’s last wor has left the UART transmit buffers
// EDTPTI not defined in cdefBF50x_base.h
#ifndef EDTPTI
#define EDTPTI 0x10
#endif
     ssync();
     *pUART0_IER_SET = ETBEI | EDTPTI;
After DMA work unit complete Interrupt not generated.
