Write a sequence and read it back from control port
Question asked by op-electronics on Oct 31, 2016
Latest reply on Nov 1, 2016 by op-electronics
i'm trying to write a sequence to eeprom through control port and then read it back. The sequence file contains a single read to aux adc 0 register (0xF5A0).
The sequence is working properly because when launching the sequencer window i can read auxadc0 in the capture window.
I2C communication is working too cause i was able to write and read a sequence with a write to a parameter block, so i can assume that the procedure is correct.
By the way, when i try to write a read from auxadc0, i can't get anything back.
Tried the same thing with a sequence write to MP6 but didn't work either.
What i'm doing or thinking the wrong way?
Can you help?
Thank you!
Omar
