(ADV7480) To output 1080p@60 with MIPI
Question asked by donadona999s on Oct 31, 2016
Latest reply on Apr 26, 2017 by confuindustries
Hi !
I have some question about ADV7480
Q1)
I was reading ADV7480's required setting.
At the setting file , it says it supports720p @ 60
Is there any file to support 1080p @ 60?
Q2)
The "required setting" is for general.
Not only for EVAL-Board .
Is my understanding correct?
Q3)
To write EDID
  ①IO MAP Address 0xF6
      => 0x68
  ②HDMI RX Repeater Map Address 0x70[7:4] primary_edid_size[3:0]
   =>0010:256byte
  ③HDMI RX Repeater Map Address 0x7A[6:4] edid_segment_pointer[2:0]
   =>000:First 256 bytes of EDID data area
  ④HDMI RX Repeater Map Address 0x7D[0] dual_edid_enable_port_a
   =>0:Primary EDID data area
  ⑤EDID MAP Address 0x00-0xFF
      =>Write EDID
This is the procedure.
Is there any register setting to add this?
Q4)
To use HPA automatically
  HDMI RX Map, Address 0x6C[2:1] hpa_auto_int_edid[1:0]
     =>10:EDID & when ADV7480 detect the HDMI cable connected , HPA will work
  ②HDMI RX Map, Address 0x6C[0] hpa_manual
 =>0:HPA takes its value based on HPA_AUTO_INT_EDID
Best regards
Kawa
