CAN Module : Acknowlegdement errors
Question asked by rschoop on Aug 23, 2011
Latest reply on Aug 24, 2011 by rschoop
Hello All,
I am trying to put the CAN module of  a BF538F to work on a CAN bus but still with no luck.
I am working on a BF538F EZ-kit lite board version 1.2. Besides this board I also have two CANUSB modules (www.canusb.com).
I can put the two CANUSB modules work properly on the CAN bus, so I can let them communicate with each other.
Below you can find a very basic code that is supposed to transmit a frame each second.
But I get many ACK errors. On a oscilloscope I see that the CAN transceiver keeps
retransmitting, but it does'n receive a dominant ACK bit from the receiver CANUSB module.
The strange thing is when I enable the debug mode,  everything work fine on the CAN Bus.
The reason is that the  Auto ACK mode is enabled.
Can someone have a look at this code and give me some advice ??
Thanks in advance,
rschoop
<code>
* can_v02.c
#include <cdefBF538.h>
#include <ccblkfn.h>
#include <sys\exception.h>
volatile unsigned int ctr1=0;
volatile unsigned int ctr2=0;
volatile unsigned int ctr3=0;
volatile unsigned short a = 0;
volatile unsigned short dummy1=0;
volatile unsigned short dummy2=0;
volatile unsigned short dummy3=0;
volatile unsigned short dummy4=0;
volatile unsigned short dummy5=0;
volatile unsigned short dummy6=0;
volatile unsigned short dummy7=0;
volatile unsigned short dummy8=0;
volatile unsigned short word3=0;
volatile unsigned short word2=0;
volatile unsigned short word1=0;
volatile unsigned short word0=0;
EX_INTERRUPT_HANDLER(TMR0)
*pTIMER_STATUS = 0x1;
*pCAN_MB31_DATA3 = 0x0201 ;
*pCAN_MB31_DATA2 = 0x0c00 ;
*pCAN_MB31_DATA1 = a ;
*pCAN_MB31_DATA0 = a ;
a++;   //  word0 and word1 are incremented each second
dummy1 =  *pCAN_STATUS ;
dummy2 =  *pCAN_INTR ;
dummy3 =  *pCAN_GIS ;
dummy4 =  *pCAN_ESR ;
*pCAN_TRS2 = 0x8000 ;
ctr1++;  //  number of timer0 interrupts are counted
ssync();
EX_INTERRUPT_HANDLER(CAN_TX)
ctr2++ ;
*pCAN_TA2 =  0x8000 ;
*pCAN_MBTIF2 = 0x8000 ;
ssync();
EX_INTERRUPT_HANDLER(CAN_ERR)
dummy5 =  *pCAN_STATUS ;
dummy6 =  *pCAN_INTR ;
dummy7 =  *pCAN_GIS ;
dummy8 =  *pCAN_ESR ;
ctr3++ ;
*pCAN_GIS = 0x07ff ;   //  W1C
*pCAN_GIF = 0 ;        //   According to HRM write 0 to clear
*pCAN_ESR = 0xfc  ;    // W1C
ssync() ;
void main( void )
int ms = 100000;
int period = 0 ;
int width = 0 ;
*pSIC_IAR2=0x66666660;    //     Timer0 :  IVG 7
*pSIC_IAR5=0x16666666;    //     CAN Rx :  IVG 8
*pSIC_IAR6=0x66666662;    //     CAN Tx :  IVG 9
*pSIC_IAR4=0x66666663;    //     CAN Error :  IVG 10
*pSIC_IMASK0=0x00010000;     //   Timer 0  interrupt enabled
*pSIC_IMASK1=0x00010001;     //   CAN  Tx , CAN Error interrupt enabled
register_handler(ik_ivg7, TMR0);
register_handler(ik_ivg9, CAN_TX);
register_handler(ik_ivg10, CAN_ERR);
period = 1000 * ms ;     //   timer0 period time is 1 second
width = 0.7 * period ;
*pTIMER0_CONFIG=0x1D;
*pTIMER0_PERIOD=period;
*pTIMER0_WIDTH=width ;
*pCAN_CLOCK = 19;     // 500 kbps    CCLK is 400 MHz,  SCLK is 100 MHz
*pCAN_TIMING = 0x0334 ;
*pCAN_MB31_ID1 = 0x1f7c;    //   CAN  ID is  0x7df
*pCAN_MB31_ID0 = 0 ;
*pCAN_MB31_LENGTH = 8 ;
*pCAN_MC2 = 0x8000 ;
//*pCAN_OPSS2 = 0x8000 ;
*pCAN_MBIM2 = 0x8000 ;
*pCAN_GIM = 0x07ff ;
//*pCAN_DEBUG = 0x8008 ;
//*pCAN_DEBUG = 0x8038 ;
*pCAN_CONTROL = 0 ;
while (  (*pCAN_STATUS & 0x0080) != 0 )
ctr1++;
*pTIMER_ENABLE=1;
while (1) ;
</code>
