AD9361 l_clk
Question asked by lesley on Oct 18, 2016
Latest reply on Oct 18, 2016 by andrei_g
Hi all,
      I have a question about the data_clk of ad9361. We connect two fmcomms3 with VC707 and our hdl design refer to the reference hdl of fmcomms5.
     I want to check out the data_clk output of two fmcomms3, so we test the l_clk of two axi_ad9361 IP core.  Because the l_clk is generated from data_clk as following:
  ad_lvds_clk #(
    .BUFTYPE (PCORE_DEVICE_TYPE))
  i_clk (
    .clk_in_p (rx_clk_in_p),
    .clk_in_n (rx_clk_in_n),
    .clk (l_clk));
   The l_clk of the master ad9361 seems correct, however the l_clk of the slave one is totally in a mess. And if I change the slave fmcomms3 board to another one, the l_clk is still incorrect. I am quite confused. In my opinion, the data_clk is generated by the bbpll in the ad9361, so if the chip works, the data_clk(l_clk) should be good even if the timing constraints are not met. We use the no-os driver code that ADI provides and both ad9361 are successfully initialized.
   Is there something wrong with my opinion? And do you guys have any idea what causes this problem?
Thanks!
Lesley
