GNU Radio Error with ADRV9371 and ZC706: Device not Found
Question asked by cmazzola on Oct 13, 2016
Latest reply on May 5, 2017 by pcercuei
I'm attempting to use pre-installed GNU radio build with  the ADRV9371 evaluation board with the ZC706.  I'm able to use the ADI IIO Scope - iio_info displays all the devices (local host)
Running one of the GNU examples on the desktop, cyclic-sine.grc; I tried using for the parameter hostname 'localhost' and '127.0.0.1' but with either value I get the following message shown below
Should I be entering something else in the parameter block?
>>> Warning: This flow graph may not have flow control: no audio or RF hardware blocks found. Add a Misc->Throttle block to your flow graph to avoid CPU congestion.
Executing: "/home/analog/Desktop/gnuradio-examples/top_block.py"
Fontconfig warning: ignoring C.UTF-8: not a valid language tag
Traceback (most recent call last):
  File "/home/analog/Desktop/gnuradio-examples/top_block.py", line 85, in <module>
    tb = top_block(hostname=options.hostname)
  File "/home/analog/Desktop/gnuradio-examples/top_block.py", line 49, in __init__
    self.iio_fmcomms2_source_0 = iio.fmcomms2_source(hostname, 2400000000, samp_rate, 1 - 1, 200000, True, True, False, False, 0x8000, True, True, True, "manual", 64.0, "manual", 64.0, "A_BALANCED")
  File "/usr/lib/python2.7/dist-packages/gnuradio/iio/iio_swig.py", line 170, in make
    return _iio_swig.fmcomms2_source_make(*args, **kwargs)
RuntimeError: Device not found
>>> Done
