HMC733 tune voltage range for 10-20GHz operation
Question asked by kbs on Oct 7, 2016
Latest reply on Oct 10, 2016 by dmailloux
If I had a rail to rail opamp as a loop amp, could I use 0-21V rails on the opamp an still be able to tune HMC733 from 10-20GHz?
The opamp I had in mind can output voltages within 0.2V of its rails.
In other words, is 0.2V a low enough voltage to tune HMC733 to 10GHz? I want to know if I can avoid using a negative supply on the opamp with R-R output.
thanks
