Error occured when creating  ZedBoard AD9361 design
Question asked by zkf0100007 on Oct 1, 2016
Latest reply on Oct 15, 2016 by zkf0100007
1.Download a ZIP and extract 'hdl-master' in my D:/WORK/Vivado/ folder on Windows7 machine.
2.Second step is to build a few Analog Devices IP required to create ZedBoard AD9361 design. Run Xilinx Vivado, open a TCL console, change directories and 'source' a .tcl scripts. For example, to build AXI_CLKGEN IP:
cd D:/WORK/Vivado/hdl-master/library/axi_clkgen
source ./axi_clkgen_ip.tcl
After script finish, close created project and build the next.
For ZedBoard we have build the next IP's:
D:/WORK/Vivado/hdl-master/library/axi_hdmi_tx
D:/WORK/Vivado/hdl-master/library/axi_spdif_tx
D:/WORK/Vivado/hdl-master/library/axi_i2s_adi
D:/WORK/Vivado/hdl-master/library/axi_ad9361
D:/WORK/Vivado/hdl-master/library/axi_dmac
D:/WORK/Vivado/hdl-master/library/util_axis_fifo
D:/WORK/Vivado/hdl-master/library/util_axis_resize
D:/WORK/Vivado/hdl-master/library/util_upack
D:/WORK/Vivado/hdl-master/library/util_cpack
D:/WORK/Vivado/hdl-master/library/util_wfifo
D:/WORK/Vivado/hdl-master/library/util_tdd_sync
3.After we done with all required IP's, we can build AD9361 reference design for ZedBoard. In a Tcl Console change directory to AD9361 and run 'system_project' script.
cd d:/work/vivado/hdl-master/projects/fmcomms2/zed
source system_project.tcl
Unfortunatly, errors occured while synthesis the projects. The error log is shown below:
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_axi_hdmi_clkgen_0'...
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_clkgen_v1_0/eb15edc8/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_rst.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_clkgen_v1_0/eb15edc8/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_mmcm_drp.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_clkgen_v1_0/eb15edc8/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_axi.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_clkgen_v1_0/eb15edc8/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_clkgen.v' to.
ERROR: [IP_Flow 19-167] Failed to deliver one or more file(s).
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'system_axi_hdmi_clkgen_0'. Failed to generate 'Synthesis' outputs:
ERROR: [IP_Flow 19-98] Generation of the IP CORE failed.
ERROR: [BD 41-1030] Generation failed for the IP Integrator block axi_hdmi_clkgen
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_axi_hdmi_core_0'...
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_csc_1_mul.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_csc_1_add.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_csc_1.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_mem.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_rst.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_csc_RGB2CrYCb.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_ss_444to422.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_xfer_cntrl.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_xfer_status.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_clock_mon.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_axi.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_hdmi_tx.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_hdmi_tx_v1_0/8027155a/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_axi_ip_constr.xdc' to.
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'system_axi_hdmi_core_0'. Failed to generate 'Synthesis' outputs:
ERROR: [BD 41-1030] Generation failed for the IP Integrator block axi_hdmi_core
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_axi_hdmi_dma_0'...
INFO: [BD 41-1029] Generation completed for the IP Integrator block axi_hdmi_dma .
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_sys_audio_clkgen_0'...
INFO: [IP_Flow 19-1686] Generating 'Implementation' target for IP 'system_sys_audio_clkgen_0'...
INFO: [IP_Flow 19-1706] Not generating 'Implementation' target for IP 'system_sys_audio_clkgen_0'. Target already exists and is up to date.
INFO: [BD 41-1029] Generation completed for the IP Integrator block sys_audio_clkgen .
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_axi_spdif_tx_core_0'...
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_spdif_tx_v1_0/dce0d057/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/dma_fifo.vhd' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_spdif_tx_v1_0/dce0d057/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/axi_ctrlif.vhd' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_spdif_tx_v1_0/dce0d057/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/axi_streaming_dma_tx_fifo.vhd' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_spdif_tx_v1_0/dce0d057/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/pl330_dma_fifo.vhd' to.
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'system_axi_spdif_tx_core_0'. Failed to generate 'Synthesis' outputs:
ERROR: [BD 41-1030] Generation failed for the IP Integrator block axi_spdif_tx_core
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_axi_i2s_adi_0'...
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_i2s_adi_v1_0/4c7b9390/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/dma_fifo.vhd' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_i2s_adi_v1_0/4c7b9390/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/axi_ctrlif.vhd' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_i2s_adi_v1_0/4c7b9390/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/axi_streaming_dma_tx_fifo.vhd' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_i2s_adi_v1_0/4c7b9390/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/axi_streaming_dma_rx_fifo.vhd' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_i2s_adi_v1_0/4c7b9390/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/pl330_dma_fifo.vhd' to.
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'system_axi_i2s_adi_0'. Failed to generate 'Synthesis' outputs:
ERROR: [BD 41-1030] Generation failed for the IP Integrator block axi_i2s_adi
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_axi_iic_fmc_0'...
INFO: [IP_Flow 19-1687] The current project language is set to Verilog. However IP 'system_axi_iic_fmc_0' does not support 'Verilog Synthesis' output products, delivering 'VHDL Synthesis' output products instead.
INFO: [IP_Flow 19-1686] Generating 'Implementation' target for IP 'system_axi_iic_fmc_0'...
INFO: [IP_Flow 19-1706] Not generating 'Implementation' target for IP 'system_axi_iic_fmc_0'. Target already exists and is up to date.
INFO: [BD 41-1029] Generation completed for the IP Integrator block axi_iic_fmc .
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_xbar_0'...
INFO: [BD 41-1029] Generation completed for the IP Integrator block axi_cpu_interconnect/xbar .
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_axi_ad9361_0'...
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_mul.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_dds_sine.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_pnmon.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_dds_1.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_xfer_cntrl.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_xfer_status.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_rst.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_dds.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_datafmt.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_dcfilter.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_iqcor.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_addsub.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_clock_mon.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_adc_channel.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_dac_channel.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_lvds_clk.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_lvds_in.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_lvds_out.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_tdd_control.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_delay_cntrl.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_adc_common.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_dac_common.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_tdd_cntrl.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_axi.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_ad9361_v1_0/2186b966/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_axi_ip_constr.xdc' to.
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'system_axi_ad9361_0'. Failed to generate 'Synthesis' outputs:
ERROR: [BD 41-1030] Generation failed for the IP Integrator block axi_ad9361
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_axi_ad9361_dac_dma_0'...
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/util_axis_fifo_v1_0/7d342d98/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/sync_gray.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/util_axis_fifo_v1_0/7d342d98/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/sync_bits.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_dmac_v1_0/49319d20/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/sync_bits.v' to.
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/axi_dmac_v1_0/49319d20/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/up_axi.v' to.
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'system_axi_ad9361_dac_dma_0'. Failed to generate 'Synthesis' outputs:
ERROR: [BD 41-1030] Generation failed for the IP Integrator block axi_ad9361_dac_dma
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_util_ad9361_dac_upack_0'...
INFO: [BD 41-1029] Generation completed for the IP Integrator block util_ad9361_dac_upack .
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_axi_ad9361_adc_dma_0'...
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'system_axi_ad9361_adc_dma_0'. Failed to generate 'Synthesis' outputs:
ERROR: [BD 41-1030] Generation failed for the IP Integrator block axi_ad9361_adc_dma
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_util_ad9361_adc_pack_0'...
INFO: [BD 41-1029] Generation completed for the IP Integrator block util_ad9361_adc_pack .
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_util_ad9361_adc_fifo_0'...
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/util_wfifo_v1_0/af75d3ab/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_mem.v' to.
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'system_util_ad9361_adc_fifo_0'. Failed to generate 'Synthesis' outputs:
ERROR: [BD 41-1030] Generation failed for the IP Integrator block util_ad9361_adc_fifo
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_util_ad9361_tdd_sync_0'...
CRITICAL WARNING: [IP_Flow 19-664] Failed to create directory 'd:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/ipshared/analog.com/util_tdd_sync_v1_0/fd491cc4/d:/WORK/Vivado/hdl-master/library/common' to copy 'd:/WORK/Vivado/hdl-master/library/common/ad_tdd_sync.v' to.
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'system_util_ad9361_tdd_sync_0'. Failed to generate 'Synthesis' outputs:
ERROR: [BD 41-1030] Generation failed for the IP Integrator block util_ad9361_tdd_sync
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_ila_adc_0'...
INFO: [BD 41-1029] Generation completed for the IP Integrator block ila_adc .
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_ila_tdd_0'...
INFO: [BD 41-1029] Generation completed for the IP Integrator block ila_tdd .
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_auto_pc_0'...
INFO: [BD 41-1029] Generation completed for the IP Integrator block axi_cpu_interconnect/s00_couplers/auto_pc .
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'system_auto_pc_1'...
INFO: [BD 41-1029] Generation completed for the IP Integrator block axi_hp0_interconnect/s00_couplers/auto_pc .
INFO: [BD 41-1379] This design does not contain any processor.
Exporting to file d:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/hw_handoff/system.hwh
Generated Block Design Tcl file d:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/hw_handoff/system_bd.tcl
Generated Hardware Definition File d:/work/vivado/hdl-master/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/hdl/system.hwdef
generate_target: Time (s): cpu = 00:00:37 ; elapsed = 00:00:38 . Memory (MB): peak = 1212.785 ; gain = 27.242
ERROR: [Common 17-39] 'generate_target' failed due to earlier errors.
    while executing
"generate_target {synthesis implementation} [get_files  $project_system_dir/system.bd]"
    (procedure "adi_project_create" line 103)
    invoked from within
"adi_project_create fmcomms2_zed"
    (file "system_project.tcl" line 6)
