AD9361 Filter Wizard Fcutoff
Question asked by Carsten on Sep 30, 2016
Latest reply on Oct 5, 2016 by timh
I have some problems with the filter wizard 16.1.2.
I made a RX filter for Fpass = 20.48 MHz and Fstop = 25.6 MHz.After putting it to noos and sweeping a carrier over the full spectrum, the gain is falling from DC to +/-Fpass of about 3dB.
By increasing the RFbw manually by using ad9361_set_rx_rf_bandwidth the gain seems to get better at some point and overshootinga a tiny bit later on.
I noticed the Fcutoff(Analog) and the RF field acting weird. Fcutoff should be set to 20.48*1.4=28.672 but is set to 27.1117 and the RF is should be set to 20.48*2.5=51.2 but is set to 38.731. If i put the cursor in the Fcutoff field and hitting enter the values are decreasing even more.
Here are my RX-Settings:
          int_FIR: 1
             Fpass: 20480000
             Fstop: 25600000
             Apass: 0.0100
             Astop: 80
          FIRdBmin: 80
             Rdata: 61440000
              Type: 'Lowpass'
              wnom: 28672000
              RFbw: 51200000
          PLL_mult: 2
          PLL_rate: 983040000
              RxTx: 'Rx'
           DAC_div: 1
               HB3: 2
               HB2: 2
               HB1: 1
               FIR: 2
              phEQ: 0
    converter_rate: 491520000
(from the ad9361_settings.mat), wnom and RFbw get overwritten by GUI.
and the output for No-OS:
{ //RXFIR
        3, // rx
        -6, // rx_gain
        2, // rx_dec
        {-87,-8,157,276,160,-148,-317,-84,351,444,-44,-618,-513,324,954,458,-796,-1309,-180,1503,1607,-455,-2503,-1744,1681,3992,1593,-4182,-6964,-1111,11964,23685,25354,15873,2642,-5185,-4436,602,3525,1987,-1263,-2419,-749,1352,1558,53,-1193,-898,297,921,427,-415,-630,-128,394,380,-26,-298,-178,124,275,184,25,-78,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, // rx_coef[128]
        64, // rx_coef_size
        {983040000,491520000,245760000,122880000,122880000,61440000}, // rx_path_clks[6]
        38731004 // rx_bandwidth
So what is going wrong?
Why aren't the values for RFbw matching?
btw: what is the resolution of the RFBW setting, the steps actually applied seem to be large.
