2147x FFTA
Question asked by Clack on Sep 29, 2016
Latest reply on Nov 8, 2016 by Jithul_Janardhanan
I debug the 2147x FFTA and have a problem. When I set a breakpoint at FFTA ISR (FFTIsr), the dsp work correctly and everytime the pc can stop at breakpoint. But the dsp runs at full speed, then cces report a error:
Core access to a SPORT/LINK Port is hung at PC:0x1244c2
I don't know what happen, and who can tell me what to do . Thanks!
 * 21479flashtest.c
#include <sys/platform.h>
#include "21479flashtest.h"
#include <stdio.h>     /* Get declaration of puts and definition of NULL. */
#include <builtins.h>  /* Get definitions of compiler builtin functions */
#include <platform_include.h>      /* System and IOP register bit and address definitions. */
#include <processor_include.h>
#include <services/int/adi_int.h>  /* Interrupt Handler API header. */
#include "adi_initialize.h"
#include <sru.h>
 * If you want to use command program arguments, then place them in the following string.
extern void initPLL(void);
extern void initExternalMemory(void);
int FFTtest(void);
void FFTIsr(void);
#define PCI 0x80000
#define COEFFSEL 0x100000
#define OFFSET_MASK 0x7FFFF
volatile int fft_done=0;
volatile float inputdata[512] = {
                                                        #include "input512.dat"
                                                        };  /*input data is in the form of real followed by imag.*/
static float coeffdata[512] = {
                                                        #include "twiddle256complx.dat"
                                                        }; /*512 twiddle data in the form of real and imag. coeff are in terms of cos, -sin, sin, cos.*/
volatile float outputdata[512];
int dataTxTCB[6] = {0,0,0,512,1,(int)inputdata};
int coeffTCB[6] = {0,0,0,512,1,(int)coeffdata};
int dataRxTCB[6] = {0,0,0,512,1,(int)outputdata};
int I1[256] ={};
int Q1[256] ={};
int I2[256] ={};
int Q2[256] ={};
float SUMI[256] ={};
float SUMQ[256] ={};
float DIFFI[256] ={};
float DIFFQ[256] ={};
int main(void)
//      asm("JUMP 0;");
         int temp;
         int i,a;
         /* Initialize managed drivers and/or services at the start of main(). */
         adi_initComponents();
         /* Initialize SHARC PLL*/
         initPLL();
         /* Initialize DDR2 SDRAM controller to access memory */
//      initExternalMemory();
    a= 0;
         *pPICR0 =P3I4|P3I3|P3I1|P3I0;
         adi_int_InstallHandler(ADI_CID_P3I, FFTIsr, NULL, true);
         SRU(HIGH, PBEN09_I);
         SRU(HIGH,DAI_PB09_I);
         for(i=0;i<256;i++)
                   I1[i] = i;
                   I2[i] = i+1;
                   Q1[i] = i;
                   Q2[i] = i+2;
         FFTtest();
         while(1)
         /* Begin adding your custom code here */
         return 0;
int FFTtest(void)
         unsigned int temp;
         /* Selecting FFT accelerator */
         *pPMCTL1&=~(BIT_17|BIT_18);
         *pPMCTL1|=FFTACCSEL;
         /*PMCTL1 effect latency*/
         //asm("nop;nop;nop;nop;");
         NOP();NOP();NOP();NOP();NOP();
         /*Clearing the FFTCTL registers*/
         *pFFTCTL2=0;
         *pFFTCTL1=FFT_RST;
         temp= ((int)(dataTxTCB) + 5) & OFFSET_MASK;  /*Set up coeff TCB*/
         coeffTCB[0]= temp;
         *pCPIFFT= (((int)coeffTCB+5) & OFFSET_MASK)|COEFFSEL;   /* Start transmit TCB.*/
         /* Enable receiveTCB   need not wait for the transmit TCB to complete. */
         temp = PCI;  /* Enables interrupt after DMA for receive*/
         dataRxTCB[0] = temp;
         temp= (int)dataRxTCB + 5;
         *pCPOFFT = temp;   /* Starts DMA.*/
         *pFFTCTL2=VDIMDIV16_16|FFT_LOG2VDIM_8;  /* Set up VDIM values*/
         *pFFTCTL1=FFT_EN|FFT_START|FFT_DMAEN;
//      while((*pFFTDMASTAT & ODMACHIRPT)==0);
//      puts("256_Point_FFT_completed");
         return 0;
void FFTIsr(void)
{SRU(HIGH,DAI_PB09_I);
          unsigned int state=0;
//      state= *pFFTDMASTAT;
         FFTtest();
         SRU(LOW,DAI_PB09_I);
