SMC access abnormal sequence on Griffin
Question asked by robin.hu Employee on Sep 28, 2016
Latest reply on Oct 7, 2016 by nithya.koch
On Griffin board, SMC was used to access the memory in FPGA, with logic analyzer we found the order of write/read access was unexpectedly changed and thus inconsistent with the sequence of code in program.
More details please check the attached files and test project.
Please try to help explain this abnormal test result.
Issue Case#1
  1. TestCode
uint32_t i;
*pREG_SMPU0_SECURECTL = (ENUM_SMPU_SECURECTL_WSECEN
                                                | ENUM_SMPU_SECURECTL_WNSDIS
                                                | ENUM_SMPU_SECURECTL_RSECEN
                                                | ENUM_SMPU_SECURECTL_RNSDIS
                                                | ENUM_SMPU_SECURECTL_SBEDIS);
SMC_Bank_Config(1, SMC_BCTL_VALUE,SMC_BTIM_VALUE,SMC_BETIM_VALUE);
*pREG_SPU0_SECUREP48=0x3;
while(1)
                     *(SMC_LinkPort)=0xaaaa;
                     *(SMC_LinkPort+0x5555)=0x5555;
                     *(SMC_LinkPort+0xaaaa)=0x55aa;
                     read_data1[0]=*(SMC_LinkPort+0x1000);
                     read_data1[1]=*(SMC_LinkPort+0x2000);
                     read_data1[2]=*(SMC_LinkPort+0x3000);
                     for(i=0;i<500;i++)
  1. Test Result
With Logic Analyzer to capture the SMC access from the beginning of loops.
(1) First loop(see following pic#1):
It has abnormal access sequence (expected to be 3 writes follows with 3 reads):
       2 writes==>1 read==>1 write==>2 reads
   2 Writes:
1 Reads:
   1 Writes:
   2 Reads
(2) 2nd loop(see following pic#2):
   Same error as 1st loop.
(3) 3rd loop(see following pic#3):
       1 write==>1 read==>1 write==>1 read==>1 write==>1 read
     1 write:
     1 read:
     1 write:
     1 read:
   1 write
     1 read:
(4) >4th loops
     Same as 3rd loop
Normal Case #2
  1. Test Code
     uint32_t i;
              while(1)
        | ENUM_SMPU_SECURECTL_RSECDIS
              *pREG_SMPU0_SECURECTL = (ENUM_SMPU_SECURECTL_WSECDIS
                     //for(i=0;i<2000;i++)
                     for(i=0;i<500;i++)
  1. Test Result
   The read/write access is as expected, ie, write 3 times then read 3 times.
Issue Case#3
  1. TestCode
  uint32_t i;
              while(1)
                     for(i=0;i<500;i++)
  1. Test result
(1) place breakpoint at *pREG_SMPU0_SECURECTL = xxx code line,
(2) run to breakpoint
(3) 3 writes are as normal.
(4) step run
   It will result unexpected 2 reads (see following pic), ie,
