HMC1082 Maximum Ratings
Question asked by Luca_wave on Sep 26, 2016
Latest reply on Sep 30, 2016 by kkaya
Reading the HMC1082 datasheet I could not find the maximum ratings for the gate voltage, only the suggested range from -2V to zero in which the Idd can reach 220mA.
I'm following this procedure to turn on the amplifier with the minimum noise produced on the output:
- Set the gate voltage to a high negative level
- Set the drain voltage to the operating tension
- Raise Vg to the operating level
Is this procedure correct or needed at all? If so, for the first step I need to know what the correct level is, -2V or higher?
Thank you all in advance for any feedback,
Luca
