Output jitter without using internal PLL
Question asked by flai71 on Aug 17, 2011
Latest reply on Oct 19, 2011 by flai71
Hallo,
I have a problem with my DDS application getting output jitter if the internal PLL is not used.
Attached the schematic to see how the AD9958 is connected. I didn't put all pages to make it simple, even though I have three devices in the same board.
I have a programming setup that allows me to generate the desired output frequencies. Such a setup is below listed.
Chip select HIGH (default state)
Chip select LOW
Instruction byte = 0 (for CSR register)
CSR = 0x40 (0x40 for first channel or 0x80 for second channel)
Chip select HIGH
Chip select LOW
Instruction byte = 1 (for FR1 register)
FR1[23..16] = 0x97
FR1[15..8] = 0x00
FR1[7..0] = 0x00
Chip select HIGH
I/O update HIGH
I/O update LOW
Chip select LOW
Instruction byte = 2 (for FR2 register)
FR2[15..8] = 0x00
FR2[7..0] = 0x40
Chip select HIGH
I/O update HIGH
I/O update LOW
Chip select LOW
FR2[15..8] = 0x00
FR2[7..0] = 0xC0
Chip select HIGH
I/O update HIGH
I/O update LOW
Chip select LOW
Instruction byte = 3 (for CFR register)
CFR[23..16] = 0x00
CFR[15..8] = 0x03
CFR[7..0] = 0x00
Chip select HIGH
I/O update HIGH
I/O update LOW
Chip select LOW
Instruction byte = 3 (for CFTW0 register)
CFTW0[31..24] = 0xDATA
CFTW0[23..16] = 0xDATA
CFTW0[15..8] = 0xDATA
CFTW0[7..0] = 0xDATA
Chip select HIGH
I/O update HIGH
I/O update LOW
I admit no use of the Master Reset after power-up; but the device work properly.
With such a programming the DDS works internally at 500MHz; refclk 100MHz multiplied 5 times.
On pin SYNC_OUT I get 125MHz. Problem is that VoH is 1,5V only and the buffer 49FCT3805 is out of spec on both ViHmin and Maxfreq.
I tried to reduce PLL freq to 400MHz writing 0x93 in the FR1 register most significant byte. That works but still the SYNC_OUT VoH level is low, around 1,7V.
I didn't understand why it is so low. Either I didn't find on the datasheet a frequency limit for that pin, so that I assume it can run up to Max PLL freq divided time 4.
Forced to get the right VoH level on the SYNC_OUT pin I tried to don't use the PLL writing 0x00 in the FR1 register most significant byte.
The SYNC_OUT pin has a excellent 25MHz square wave with 25% dutycycle.
Counterwise the DDS outputs has a huge jitter that makes it unusable.
Could you please advise what I am doing wrong in my programming or connection? Or other idea on how to solve the SYNC_OUT level problem?
Thanks
Regards
Flavio
