About ADV7619 audio output
Question asked by WilliamLian Employee on Sep 20, 2016
Latest reply on Sep 23, 2016 by JeyasudhaMuthuPerumal
a customer  is debugging ADV7619, there’s an issue about audio output.
  1. Input signal: PCM, processed with SPDIF+HDMI
  2. Output by AP2 port.
  3. By the AP2 port, can get the audio signal, but it heard like noise, was not same as the audio source.
  4. Customer setup
  5. Customer just modify below register, other registers with default value.
I2C slave address
 register address
configure data
0x4c
0xfd
0x44
0x4c
0xfb
0x68
0x4c
0x01
0x06
0x4c
0x00
0x02
0x4c
0x03
0x80
0x4c
0x15
0xb8
0x4c
0x19
0x80
0x4c
0x0c
0x42
0x34
0x01
0x01
0x4c
0x15
0xa8
need ADI help to confirm for normal audio output, whether the configure data of above registers are OK, what’s the suggestion for customer to get ‘normal’ audio output by AP1? Which register setup will effect audio output?
BTW,measured the output clock, the LRCLK is 48kHz, the SCLK is 3.072MHz, the MCLK is 12.28MHz
