ADV7610 RGB output - 50 ohm impedance
Question asked by DenisDarmon on Sep 13, 2016
Latest reply on Sep 14, 2016 by GuenterL
Most video devices with RGB output recommend using 50 ohm impendance.
1) If using 50-ohm series resistor on each signal line, do the traces still need to be 50-ohm impedance controlled on PCB?
2) And if so does the impedance need to be controlled on both sides of the resistor (from ADV7610 to resistor and from resistor display/connector)?
3) Can the series resistors be removed if the PCB trace impedance is controlled at 50-ohm?
Thanks.
