Quickest way to fix "Build being ghosted out"
Question asked by MikeSmithCanada on Sep 9, 2016
Latest reply on Sep 30, 2016 by MikeSmithCanada
Hi
This is a problem that I think CrossCore inherits from Eclipse and CrossCore 2.3.0 seems to have a very bad case of it
I am using CrossCore 2.3.0 -- which is essentially Eclipse Mars + ADI plugin -- working with BF533, 21469 and Sc589 with project ion emulator and simulator mode
Also using Eclipse Mars + IAR plugin on Cortex2, Cortex4 and wondering whether it might be an alternative to CrossCore gcc ARM when working with SC589 Cortex 7 (But I have not got far on that issue)
Problem is
We have several projects open -- e.g. Library I am building and a Demo that uses the library
Scenario
I change to Library -- rebuild the project
Change to Demo -- Have to clean the project as I can find no way to get project to recognize library has changes. (You can't use a prebuild command as that does not happen unless CCES recognizes the project has changed -- thats another another story)
Real problem -- About 1 time in 3 -- when I switch back and forth between projects, or make changes within a project,  the Build command get greyed out.
Anybody got a quick recovery fix to get Build back -- Here is what I try
1) Clicking on another part of the project back to Build works about 1 time in 10
2) Cleaning or Closing then reopening the project works more often
3) Sometime F7 works to rebuild after Build greyed out
4) Restarting CrossCore
Regards
Mike Smith
