stevereine
details on designing in ADV7610?
Discussion created by stevereine Employee on Aug 30, 2016
Latest reply on Aug 30, 2016 by GuenterL
Inquiry Description:
Designing the ADV7610 in our new driver board.
1) Bypass caps for ADV7610 are specified as 0.01uF per UG-438 Appendix A but 220pF caps are on the ADV7610 evaluation kit (along with the recommended 0.1uF caps). Should I use 0.01uF or 220pF?
2) Should CS/ on ADV7610 be left floating per UG-438 Appendix B or grounded per eval kit schematic?
3) Using TPD12S520 for ESD protection. They recommend using 47K on the DDC_SDA/DDC_SCL lines. Is this ok with ADV7610?
