pikafu
Programming the ADS7-V2 EBZ with MATLAB
Discussion created by pikafu on Aug 22, 2016
Latest reply on Aug 23, 2016 by jbirnie
I have a problem programming the AD7-V2 board with MATLAB. My goal is to automate tone generation from the AD9162 through the AD7-V2. Specifically, the demo script I am using appears to be outdated. There are a number of string changes and variable tweaks I had to make to the GetAds7.m and AD9162.m scripts to get them somewhat working, but I am stuck now. There are a bunch of methods that do not appear to be accessible. For example:
% Set the FMC LA signal mapping
jesd204Core.Tx.SetSignalLAPort('SYNC0', 1);
where jesd204Core is an instance of dpg_interface.AttachedDevices.JESD204.
Tx is not a field of the ADS7 IHardware device, and SetSignalLAPort is not a method. I checked the programming reference which was also not helpful. There are some fields that have the right name but have moved to a different class. For instance, jesd204Core.Tx.M has been moved to the JESD204 Framer class.
At this point, the only thing I can think of to try is downloading an older version of the DPGDownloader which appears in the readme.txt with the MATLAB code I am using. Is there an updated script I can use, or am I just using the wrong code?
Using MATLAB with ADS7 Series Pattern Generators [Analog Devices Wiki]
Programming Reference [Analog Devices Wiki]
ftp://ftp.analog.com/pub/HSSP_SW/HSCDAC/dpg/matlab/AD9162_Matlab_readme.txt
