How to import  properly AD4528 SPICE model?
Question asked by vini on Aug 22, 2016
Latest reply on Aug 31, 2016 by vini
I want to simulate the behavior of the amplifier with specific feedback in SPICE.
I loaded the .cir file downloaded from the product webpage. Then right-clicked on .subckt and "create symbol".
SPICE auto-generated symbol for the amplifier, however when I click on simulate I get the following errors:
WARNING: Node NC_02 is floating.
WARNING: Node NC_01 is floating.
WARNING: Node NC_05 is floating.
Instance "m:u2:6": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u2:5": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u2:4": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u2:3": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u2:2": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u2:1": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u1:6": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u1:5": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u1:4": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u1:3": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u1:2": Length shorter than recommended for a level 2 MOSFET.
Instance "m:u1:1": Length shorter than recommended for a level 2 MOSFET.
Singular matrix:  Check node u1:7
   Iteration No. 1
Direct Newton iteration failed to find .op point.  (Use ".option noopiter" to skip.)
Starting Gmin stepping
Gmin = 10
Gmin = 1.07374
Gmin = 0.115292
Gmin = 0.0123794
Gmin = 0.00132923
Gmin = 0.000142725
Gmin = 1.5325e-005
Gmin = 1.6455e-006
Gmin = 1.76685e-007
vernier = 0.5
vernier = 0.25
vernier = 0.125
Gmin = 7.23701e-008
vernier = 0.0625
vernier = 0.03125
vernier = 0.015625
vernier = 0.0078125
Gmin = 6.9633e-008
vernier = 0.00390625
vernier = 0.00195313
vernier = 0.000976563
vernier = 0.000488281
Gmin = 6.94634e-008
   Iteration No. 2
Gmin = 0
   Iteration No. 1
Gmin stepping failed
Starting source stepping with srcstepmethod=0
   Iteration No. 1
   Iteration No. 2
Could not converge to DC with sources off!
Starting source stepping with srcstepmethod=1
   Iteration No. 1
Singular matrix:  Check node nc_02
   Iteration No. 1
Fatal Error: Singular matrix:  check node nc_02
   Iteration No. 1
This circuit has floating nodes.
what am I doing wrong?
Can I use the default opamp2 schematic symbol even though the node assignment of the symbol and the .subckt are different? (1,2,3,4,5) and (1,2,99,50,45)
Thanks
