DDR2 loopback test of ADV8005
Question asked by Kikka on Aug 19, 2016
Latest reply on Aug 26, 2016 by Kikka
Hello.
I tried the DDR2 loopback test with the following procedure using EVAL-ADV8005-SMZ.
1. power-up the EVAL-ADV8005-SMZ
2. write the loopback script
3. read 0x1AE1(lbk_test_done and lbk_test_result)
loopback script (from How do I get the DDR2 loopback test working on ADV8005 or ADV8003? )
    0x1A, 0x1A5B, 0x42, // ; DDR2 change the SDRAM to be 2Gb
    0x1A, 0x1A5F, 0x00, // ; DDR2 enable full drive strength
    0x1A, 0x1A61, 0x06, // ; DDR2 correct rdy_wr_b advancement
    0x1A, 0x1AA0, 0x13, // ; DDR2 plldll recommended values
    0x1A, 0x1AA1, 0x01, // ; DDR2 plldll power up, pll loop filter bandwidth = 1
    0x1A, 0x1AA2, 0x25, // ; DDR2 pll div 37
    0x1A, 0x1AA3, 0x1D, // ; DDR2 pre pll div ratio
    0x1A, 0x1AA4, 0x81, // ; phase selection for Memory Interface
    0x1A, 0x1AA5, 0x81, // ; phase selection for Memory Interface
    0x1A, 0x1AA7, 0x53, // ; Enable DDR2 loopback test on init
    0x1A, 0x1AA8, 0xB4, // ; DDR2 Power up pads
    0x1A, 0x1AFE, 0x08, // ; Start init and loopback test
    0x1A, 0x1A0B, 0x10, // ; enable pseudo 444 to real 444
    0x1A, 0xE649, 0x40, // ; bypass Secondary VSP
    0x1A, 0x1A9D, 0xFF, // ; Default 0x00, DDR2 clk Drive Strenght
    0x1A, 0x1A9E, 0x55, // ; Default 0x00, DDR2 clk Drive Strenght
But it seems that 0x1AE1 register is 0x03. it means lbk_test_done=1(Loopback test finished) and
lbk_test_result=1(Errors detected).
Would you please check it and tell me your advice?
Best regards.
Kikka
