【Need help】:Adv7610 can not fully display 16 Gray testing picture
Question asked by snowdream on Aug 18, 2016
Latest reply on Aug 21, 2016 by snowdream
hi all:
   Nowdays, i use adv7610 to do some testing and found out a problem need your help.
   i input a 16 Gray testing picture to adv7610 and after the process of adv7610, the output display is not very good. you can check the result in my attachment files.
   question is :
    in the black part, the black two color slides are the same and in the white part, the white two color slides are the same.In other words, acturely there should be 16 color slides but indeed i just found 14 color slides.
   the gray color slide RGB information is as following:
slideRGB
10x00x00x0
20x110x110x11
30x220x220x22
40x330x330x33
50x440x440x44
60x550x550x55
70x660x660x66
80x770x770x77
90x880x880x88
100x990x990x99
110xaa0xaa0xaa
120xbb0xbb0xbb
130xcc0xcc0xcc
140xdd0xdd0xdd
150xee0xee0xee
160xff0xff0xff
so pls help me to check which configuration of adv7610 can product into the problem?
thank you so  much.
BR
Xutao
