ADucm360 sleep (mode 4)
Question asked by shortDan on Aug 15, 2016
Latest reply on Aug 19, 2016 by ABuda
I'm trying to create a sleep function for the ADucm360 board, which will put the device to deep sleep (mode 4) for a configurable amount of miliseconds and afterwards the CPU should be woken up by the wake-up timer.
My problem is that it doesn't work. The CPU enters Mode4, but it never wakes up from it.
The wake-up timer seems to be configured correctly -independently of the sleep code ( I've tried it on the evaluation board - toggling the LED at a predefined time interval).
Here is the code snippet.
void sleep( uint32_t ms )
  int32_t index = 0;
  uint32_t miliseconds = 2*ms;
    /* enable the wake-up timer */
  pADI_WUT->T2CON = T2CON_MOD_PERIODIC|T2CON_WUEN_EN|T2CON_PRE_DIV16|T2CON_CLK_LFOSC;
  /* configure the interrupt for wake-up field D */
  pADI_WUT->T2IEN |= (0x8 & 0x1F);
  /* Configure the timeout  for the wake-up timer */
  pADI_WUT->T2WUFD0= (short)(miliseconds&0x0000FFFF);
  pADI_WUT->T2WUFD1= (short)(miliseconds>>16);
  SCB->SCR = 0x04; // sleepdeep mode
  pADI_PWRCTL->PWRKEY = 0x4859; // key1
  pADI_PWRCTL->PWRKEY = 0xF27B; // key2
  pADI_PWRCTL->PWRMOD = 0x4;  /* deep sleep mode */
/* enable the timer */
nvicEnableIRQ(WUT_IRQn);
   T2CON_ENABLE_BBA = 1;
  for (index=0;index<2;index++);
  asm("WFI");
and the wake-up timer interrupt handler
void wakeUpInterruptHandler(void)
  pADI_WUT->T2CLRI = 0;
  asm("DSB");
  //pADI_WUT->T2CON = T2CON_ENABLE_DIS;
  T2CON_ENABLE_BBA =0 ;
  nvicClearPendingIRQ(WUT_IRQn);
  nvicDisableIRQ(WUT_IRQn);
Any idea what I'm doing wrong?
