configuration line rate
Question asked by Bouchaib on Aug 15, 2016
Latest reply on Mar 22, 2018 by yzzhsx123
Hi Istvan,
Thanks for your reply .
I have a question about the procedure to change the rate .
I need to modify the parameter configuration in the file axi_jesd_gt  IP or in the block design level: hdl <https://github.com/analogdevicesinc/hdl/tree/hdl_2015_r2>/projects <https://github.com/analogdevicesinc/hdl/tree/hdl_2015_r2/projects>/daq2 <https://github.com/analogdevicesinc/hdl/tree/hdl_2015_r2/projects/daq2>/kcu105 <https://github.com/analogdevicesinc/hdl/tree/hdl_2015_r2/projects/daq2/kcu105>/system_bd.tcl.
     source $ad_hdl_dir/projects/common/kcu105/kcu105_system_bd.tcl
source $ad_hdl_dir/projects/common/xilinx/sys_dmafifo.tcl
p_sys_dmafifo  axi_ad9680_fifo 128 16
p_sys_dacfifo  axi_ad9144_fifo 128 10
source ../common/daq2_bd.tcl
set_property -dict  $axi_daq2_gt
At the beginning i think the parameter are overwrited with  system_bd.tcl because the project is created for the first time.
But when i re-launch a new generation bitstream with Vivado GUI, the file  system_bd.tcl is considered or not if i modified it (
set_property -dict  $axi_daq2_gt)?
Thanks for your help,
Bouchaib
