ADUCM360 Eval ADC input range & offset setup
Question asked by analog_mama on Aug 10, 2016
Latest reply on Sep 2, 2016 by ABuda
I am trying to test the ADC and DAC configurations in ADUCM360 Evaluation Board. I have downloaded the code given below into the ADUCM360 Evaluation Board. I have noticed that on providing any periodic signal (sin, ramp, square wave using function generator), having maximum peak-to-peak amplitude of 350mV with an Offset of 4.5V, correct waveform is obtained at the DAC end. However for all other offset values, either distorted waveform or only noise voltage is obtained at the DAC end. Why is that so? As per Hardware Reference Manual, absolute input range cannot be greater that AVDD i.e 3.6V (max). But in our case, the input signal is varying from 4.5-(0.35/2) V to 4.5+(0.35/2) V which is way beyond 3.6V. So, what is happening? I want to be clear about the calculations for the maximum input range available, offset required etc. required for ADC setup.
          Screenshots of DAC Output for sin and ramp i/p respectively::
#include <stdio.h>
#include <string.h>
#include <aducm360.h>
#include <..\common\AdcLib.h>
#include <..\common\AdcLib.c>
#include <..\common\IexcLib.h>
#include <..\common\DacLib.h>
#include <..\common\UrtLib.h>
#include <..\common\ClkLib.h>
#include <..\common\WutLib.h>
#include <..\common\WdtLib.h>
#include <..\common\GptLib.h>
#include <..\common\I2cLib.h>
#include <..\common\IntLib.h>
#include <..\common\PwmLib.h>
#include <..\common\DioLib.h>
#include <..\common\FeeLib.h>
void ADC0INIT(void);
void DACINIT(void);
void UARTINIT (void);
void delay(long int);
volatile unsigned char bSendResultToUART = 0;   // Flag used to indicate ADC0 result ready to send to UART
const unsigned int TempDataLen = 1;
unsigned char szTemp[TempDataLen] = "";                                  // Used to store ADC0 result before printing to UART
unsigned char ucTxBufferEmpty  = 0;                             // Used to indicate that the UART Tx buffer is empty
int ulADC0Result = 0;                        // Variable that ADC0DAT is read into in ADC0 IRQ
volatile unsigned char ucComRx = 0;
volatile unsigned char ucADC0ERR = 0;
unsigned long RangeMin=0x02980000;
unsigned long RangeMax=0x0FFF0000;
unsigned int Range;
unsigned long Daccode;
float scale;
int main (void)
   unsigned char i = 0;
   unsigned char nLen = 0;
  unsigned int SAMPLE_LENGTH = 1;
  unsigned long uRes_ULong = (unsigned long ) ulADC0Result;
Range=16777216;
   pADI_WDT ->T3CON = 0;
   //DioOen(pADI_GP1,0x8);                        // Set P1.3 as an output for test purposes
   WdtCfg(T3CON_PRE_DIV1,T3CON_IRQ_EN,T3CON_PD_DIS); // Disable Watchdog timer resets
   //Disable clock to unused peripherals
   ClkDis(CLKDIS_DISSPI0CLK|CLKDIS_DISSPI1CLK|CLKDIS_DISI2CCLK|CLKDIS_DISPWMCLK|CLKDIS_DIST0CLK|CLKDIS_DIST1CLK|CLKDIS_DISDMACLK);
   ClkCfg(CLK_CD0,CLK_HF,CLKSYSDIV_DIV2EN_DIS,CLK_UCLKCG);            // Select CD0 for CPU clock
   ClkSel(CLK_CD6,CLK_CD7,CLK_CD0,CLK_CD7);     // Select CD0 for UART System clock
  AdcGo(pADI_ADC0,ADCMDE_ADCMD_IDLE);                  // Place ADC0 in Idle mode
   //UARTINIT();        // Init Uart
   DACINIT();                                   // Configure DAC output
   ADC0INIT();        // Setup ADC1
   AdcGo(pADI_ADC0,ADCMDE_ADCMD_CONT);                  // Start ADC0 for continuous conversions
   NVIC_EnableIRQ(ADC0_IRQn);                                   // Enable ADC0 and UART interrupt sources
//   NVIC_EnableIRQ(UART_IRQn);
   while (1)
      if (bSendResultToUART == 1)                               // ADC result ready to be sent to UART
           uRes_ULong =  ulADC0Result;
        } // END if
   DacWr(0, (uRes_ULong)*Range);
  } // END while
   //Select IO pins for UART.
   //pADI_GP0->GPCON |= 0x3C;                     // Configure P0.1/P0.2 for UART
   pADI_GP0->GPCON |= 0x9000;                   // Configure P0.6/P0.7 for UART
   UrtCfg(pADI_UART,B9600,COMLCR_WLS_8BITS,0);  // setup baud rate for 9600, 8-bits
   UrtMod(pADI_UART,COMMCR_DTR,0);              // Setup modem bits
   UrtIntCfg(pADI_UART,COMIEN_ERBFI|COMIEN_ETBEI|COMIEN_ELSI|COMIEN_EDSSI|COMIEN_EDMAT|COMIEN_EDMAR);  // Setup UART IRQ sources
void ADC0INIT(void)
   AdcMski(pADI_ADC0,ADCMSKI_RDY,1);              // Enable ADC ready interrupt source
   AdcFlt(pADI_ADC0,16,14,FLT_NORMAL|ADCFLT_NOTCH2|ADCFLT_CHOP); // ADC filter set for 120Hz update rate        //   with chop on enabled
AdcRng(pADI_ADC0,ADCCON_ADCREF_INTREF,ADCMDE_PGA_G1,ADCCON_ADCCODE_INT); // Internal reference selected, Gain of 1, Signed integer output
  AdcBuf(pADI_ADC0,ADCCFG_EXTBUF_OFF,ADCCON_BUFBYPN|ADCCON_BUFBYPP|ADCCON_BUFPOWP|ADCCON_BUFPOWN);
AdcPin(pADI_ADC0,ADCCON_ADCCN_AIN11,ADCCON_ADCCP_AIN8); // Select AIN8 as postive input and AIN11 as        //negative input
void DACINIT(void)
   // Configure DAC output for 0-1.2V output range, Normal 12-bit mode and immediate update.
   DacCfg(DACCON_CLR_Off,DACCON_RNG_IntVref,DACCON_CLK_HCLK,DACCON_MDE_12bit);
void ADC0_Int_Handler()
   volatile unsigned int uiADCSTA = 0;
   uiADCSTA = pADI_ADC0->STA;               // read ADC status register
   ulADC0Result = AdcRd(pADI_ADC0);            // read ADC result register
   bSendResultToUART = 1;                  // Set flag to indicate ready to send result to UART
void UART_Int_Handler ()
   volatile unsigned char ucCOMSTA0 = 0;
   volatile unsigned char ucCOMIID0 = 0;
   volatile unsigned int uiUartCapTime = 0;
   ucCOMSTA0 = UrtLinSta(pADI_UART);         // Read Line Status register
   ucCOMIID0 = UrtIntSta(pADI_UART);         // Read UART Interrupt ID register
   if ((ucCOMIID0 & 0x2) == 0x2)             // Transmit buffer empty
      ucTxBufferEmpty = 1;
   if ((ucCOMIID0 & 0x4) == 0x4)             // Receive byte
      ucComRx   = UrtRx(pADI_UART);
