AD9959 USB Programming
Question asked by rancohen2000 on Aug 4, 2016
Latest reply on Aug 7, 2016 by LouijieC
I'm trying to program the AD9959 EVB using VB6 on Windows 7 and I have some problems.
I have AD9959 EVB and I can program it using the EVB software (.exe) that I have download it from the website.
this means that the drivers are OK and the EVB is recognized under windows 7 64bit.
I have download the source code from the website and the application doesn't recognize the board.
I notice that the driver of the ".exe" application is different from the source code driver.
The ".exe" application is referring to driver "ADI_CYUSB_USB4.dll" and the source code driver is referring to "Ezusb.sys".
I have search the website and found code example to work with "ADI_CYUSB_USB4.dll".
I have found some code to work with "ADI_CYUSB_USB4.dll" in those pages:
AD5933 and AD5934 evaluation board software commands
http://www.analog.com/media/en/technical-documentation/user-guides/UG-364.pdf
I did the same on AD9959 EVB and it's not working.
this is my program code:
    Public Const VRSMBus As Short = &HDE
    Public Const VRREAD As Short = 1
    Public Const VRWRITE As Short = 0
    Private Const DeviceAddress as Long = &HD
    Public HexFilePath As String
    Public DataBuffer(20) As Byte
    Public Handle As Integer
       Dim Number_Boards As Short
        Dim PartPath(127) As Byte
        Dim VID As Integer
        Dim PID As Integer
       Dim err_code as integer
       Dim DataOut as integer
       VID = 1110 '0x0456
        PID =  60965 '0xEE25 YOUR BOARD PID
        DataOut=50
        MsgBox(Number_Boards)
        err_code= Search_For_Boards(VID, PID, Number_Boards, PartPath(0))
        err_code= Connect(VID, PID, PartPath(0), Handle)
err_code= Vendor_Request(Handle, VRSMBus, DeviceAddress, CInt(256 * DataOut + AddrPtr), VRWRITE, 0, 0)
The functions "Search_For_Boards" and "Connect are working well but I can't write to device using "Vendor_Request".
I'm not sure I'm using the "Vendor_Request" correct.
what is the DeviceAddress? should it be &hD as in the example of AD5933?
does any one have good source code for AD9959 EVB that can run on WIN7?
is there any other example for ADI_CYUSB_USB4.dll?
