RX Freeze when disabling TX
Question asked by cfauvel on Aug 4, 2016
Latest reply on Aug 5, 2016 by larsc
When using the iioscope with the pre-build image for KC705 & FMCOMMS2 evaluation boards, we encounter an issue. The setup is as follow:
- Power up KC705
- Load FPGA and image with the run.tcl script (XMD)
- Open a new plot and select Voltage 0 & Voltage 1
- Just load a FIR filter (eg. LTE20MHz) and Enable FIR
- Use the FDD mode and leave all parameters to default settings
- Samples are received and plotted !
- Open the Debug page
     - Read the register 0x02
     - Write to the register 0x02 (clear bit D7)
     - Plot freeze, there is no more RX samples
     - Write to the register 0x02 (clear bit D6)
     - Plot restart but RXFIR seems disabled
     - Write to the register 0x02 (set bit D6 or D7)
     - Plot freeze
     - Write to the register 0x02 (set bit D7 or D6)
     - Plot restarts and everything is fine
It this a normal behaviour ? How can I fix this issue ? According to the datasheet and the reference manual, it seems that just writing to the registers 0x02 is required to enable/disable TX channels.
Christophe
