FMCDAQ2-EBZ SPI interface in Verilog/VHDL
Question asked by willsor on Aug 4, 2016
Latest reply on Aug 10, 2016 by CsomI
I want to implement an SPI interface to be able to use Vivado's VIO's to write data to the config memory map of the FMCDAQ2-EBZ board. 2 questions.
1.
I have been looking at the reference design for the kc705 (the board I have) and the constraints file indicates the FMC header is used for the SPI_SIDO port (data port)
"38 set_property  -dict {PACKAGE_PIN  B30 IOSTANDARD LVCMOS25} [get_ports spi_sdio]  ; ## D14  FMC_HPC_LA09_P "
However the FMCDAQ2-EBZ has an SMA port labelled SPI_SDIO.
Which interface do I use as SDIO, the FMC pin or the SMA header ?
2.
Regarding the CSB pin (confusingly labelled CSN[2:0] in your reference design). What must this be set to for each of the memory map addresses? I don't understand why its 3 bit wide.
Best regards
