ADV7511 settings
Question asked by gubuyu on Jul 29, 2016
Latest reply on Aug 26, 2016 by gubuyu
   I am using an ADV7612 to receive HDMI/DVI signals an ADV7511 to transfer DVI signals. After I configure two devices,ADV7612 works well,but adv7511 does not work !
I refer to the script ADV7612-VER.3.0c.txt to set ADV7612 and ADV7511.The settings is as shown below.
    printf("Config ADV7612 to fit: 1080p In - 24-bit RGB 444 Out\n\r");
    PSIIC0_Write(0x98, 0xFF, 0x80); //I2C Reset
    PSIIC0_Write(0x98, 0xF4, 0x80); //Config CEC slave address
    PSIIC0_Write(0x98, 0xF5, 0x7C); //Config INFOFRAME slave address
    PSIIC0_Write(0x98, 0xF8, 0x4C); //Config DPLL slave address
    PSIIC0_Write(0x98, 0xF9, 0x64); //Config KSV slave address
    PSIIC0_Write(0x98, 0xFA, 0x6C); //Config EDID slave address
    PSIIC0_Write(0x98, 0xFB, 0x68); //Config HDMI slave address
    PSIIC0_Write(0x98, 0xFD, 0x44); //Config CP slave address
    PSIIC0_Write(0x98, 0x01, 0x06); //Prim_mode = 110b HDI-GR
    PSIIC0_Write(0x98, 0x02, 0xF2); //Auto CSC, RGB out, Set RGB full grade 0-255 ,change
    PSIIC0_Write(0x98, 0x03, 0x40); //24 bit SDR 444 Mode 0
    PSIIC0_Write(0x98, 0x05, 0x28); //AV Codes Off
    PSIIC0_Write(0x98, 0x06, 0xA0); //Invert on VS,HS pins
    PSIIC0_Write(0x98, 0x0B, 0x44); //Power up part
    PSIIC0_Write(0x98, 0x0C, 0x42); //Power up part
    PSIIC0_Write(0x98, 0x14, 0x7F); //Max Drive Strength
    PSIIC0_Write(0x98, 0x15, 0x80); //Disable Tristate of Pins
    PSIIC0_Write(0x98, 0x19, 0x8F); //LLC DLL phase(0-31,set 15)
    PSIIC0_Write(0x98, 0x33, 0x40); //LLD DLL MUX enable
    PSIIC0_Write(0x44, 0xBA, 0x00); //close HDMI freerun
    PSIIC0_Write(0x64, 0x40, 0x81); //Disable HDCP 1.1 features
    PSIIC0_Write(0x4C, 0xB5, 0x03); //Setting MCLK to 512Fs
    PSIIC0_Write(0x68, 0x9B, 0x03); // ADI recommended setting
    PSIIC0_Write(0x68, 0x00, 0x08); //Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
    PSIIC0_Write(0x68, 0x02, 0x03); //Enable Ports A & B in background mode
    PSIIC0_Write(0x68, 0x83, 0xFC); //Enable clock terminators for port A & B
    PSIIC0_Write(0x68, 0x6F, 0x0C); //ADI recommended setting
    PSIIC0_Write(0x68, 0x85, 0x1F); //ADI recommended setting
    PSIIC0_Write(0x68, 0x87, 0x70); //ADI recommended setting
    PSIIC0_Write(0x68, 0x8D, 0x04); //LFG Port A
    PSIIC0_Write(0x68, 0x8E, 0x1E); //HFG Port A
    PSIIC0_Write(0x68, 0x1A, 0x8A); //unmute audio
    PSIIC0_Write(0x68, 0x57, 0xDA); //ADI recommended setting
    PSIIC0_Write(0x68, 0x58, 0x01); //ADI recommended setting
    PSIIC0_Write(0x68, 0x03, 0x98); //DIS_I2C_ZERO_COMPR
    PSIIC0_Write(0x68, 0x75, 0x10); //DDC drive strength
    PSIIC0_Write(0x68, 0x90, 0x04); //LFG Port B
    PSIIC0_Write(0x68, 0x91, 0x1E); //HFG Port B
    printf("Config ADV7511 to fit: 1080p In - 24-bit RGB 444 Out\n\r");//ADV7511 address is 0x7A
    PSIIC0_Write(0x7A, 0x01, 0x00); //Set N Value(6144)
    PSIIC0_Write(0x7A, 0x02, 0x18); //Set N Value(6144)
    PSIIC0_Write(0x7A, 0x03, 0x00); //Set N Value(6144)
    PSIIC0_Write(0x7A, 0x15, 0x20); //Input 444(RGB or YCrCb) with Separate Syncs, 48kHz FS
    PSIIC0_Write(0x7A, 0x16, 0x70); //Output format 444, 24-bit RGB input
    PSIIC0_Write(0x7A, 0x18, 0x46); //CSC disabled
    PSIIC0_Write(0x7A, 0x40, 0x80); //General Control Packet Enable
    PSIIC0_Write(0x7A, 0x41, 0x10); //Power Down control
    PSIIC0_Write(0x7A, 0x48, 0x08); //Data right justified
//    PSIIC0_Write(0x7A, 0x49,  0x00); //No truncation
    PSIIC0_Write(0x7A, 0x49, 0xA8);// Set Dither_mode - 12-to-10 bit
    PSIIC0_Write(0x7A, 0x4C, 0x04); //8bit Output
    PSIIC0_Write(0x7A, 0x55, 0x00); //Set RGB 444 in AVinfo Frame
    PSIIC0_Write(0x7A, 0x56, 0x08); //Set active format Aspect
    PSIIC0_Write(0x7A, 0x96, 0x20); //HPD Interrupt clear
    PSIIC0_Write(0x7A, 0x98, 0x03); //ADI reqired write
    PSIIC0_Write(0x7A, 0x99, 0x02); //ADI Required Write
    PSIIC0_Write(0x7A, 0x9C, 0x30); //PLL Filter R1 Value
    PSIIC0_Write(0x7A, 0x9D, 0x61); //Set clock divide
    PSIIC0_Write(0x7A, 0xA2, 0xA4); //ADI Recommended Write
    PSIIC0_Write(0x7A, 0xA3, 0xA4); //ADI Recommended Write
    PSIIC0_Write(0x7A, 0xA5, 0x04); //ADI Recommended Write
    PSIIC0_Write(0x7A, 0xAB, 0x40); //ADI Recommended Write
//    PSIIC0_Write(0x7A, 0xAF, 0x16); //Set HDMI Mode
    PSIIC0_Write(0x7A, 0xAF, 0x04); //Set DVI Mode
    PSIIC0_Write(0x7A, 0xBA, 0x60); //No clock delay
    PSIIC0_Write(0x7A, 0xD1, 0xFF); //ADI Recommended Write
    PSIIC0_Write(0x7A, 0xDE, 0xD8); //ADI Recommended Write
    PSIIC0_Write(0x7A, 0xE4, 0x60); //VCO Swing Reference Voltage
    PSIIC0_Write(0x7A, 0xFA, 0x7D); //Nbr of times to search for good phase
I red registers after configure adv7511,device address is 0x7A
device addr     register addr   value
     0x7A               0x00           0x14
     0x7A               0x01           0x00
     0x7A               0x02           0x00
     0x7A               0x03           0x00
     0x7A               0x15           0x00
     0x7A               0x16           0x00
     0x7A               0x9E           0x00
     0x7A               0x3D           0x48
     0x7A               0x3E           0x00
That means, device settings is not successfull ? why is that ?
Schematic of adv7511 is shown below.DNP means "do not place"
I do not have evaluation board.
