Motion Vector by Analog Device Module
Question asked by mantur on Jul 26, 2016
Latest reply on Aug 3, 2016 by npai2
is available a source example for __motionvect function?
It is very useful for my application but after some tests I can't find a mode for a correct use.
This is reported in the header of the file (ASM):
By using this module you agree to the terms of the Analog Devices License
Agreement for DSP Software.
Module Name     : motionvect.asm
Label Name      : __motionvect
Version         :   2.0
Change History  :
                Version     Date          Author        Comments
                2.0            01/09/2007    Arjun                Tested with VDSP++4.5
                                                        Compiler 7.2.3.2
                1.2         11/18/2002    Swarnalatha   Tested with VDSP++ 3.0
                                                        compiler 6.2.2 on
                                                        ADSP-21535 Rev.0.2
                1.1         11/13/2002    Swarnalatha   Tested with VDSP++3.0
                                                        on ADSP-21535 Rev.0.2
                1.0         07/02/2001    Vijay         Original
Description     : The assembly function does the full search block matching to
                  compute the motion vectors given a target frame and a
                  reference frame. By suitably selecting the target frame and
                  the reference frame, this routine can be used to obtain the
                  motion vectors of a P or a B frame. The target and reference
                  frames have to be of the same size and should be an integer
                  multiple of 16. The input arguments to the function are the
                  target frame address, the reference frame address, the frame
                  size, the search area factor and the start addresses of the
                  motion vectors. The macro block size is fixed to be 16x16. The
                  search area is computed based on the search area factor. It
                  specifies an integer value between 1 and 3. The search range
                  is specified as follows:
Thank you in advance for your trouble.
Regards
Manuele
