DPI pins high during after reset
Question asked by Tom00 on Aug 2, 2011
Latest reply on Aug 5, 2011 by Tom00
Hi!
I have a customized board with a 21469, where the DPI pins 12 and 13 are used as outputs. One requirement is that the DPI pins must not stay high during/after reset. On the board both pins have a pull up resistors.
Is it correct to use the init sequence from below, or do I need to bypass the default DPI config?
Actually I do not understand the DPI pins configuration (input or output) after the default DPI SRU routing. (I use LP booting.)
DPI_P12: input ???
DPI_P13: output high???
-Thomas
// setting flag pins as outputs
sysreg_bit_set( sysreg_FLAGS, (FLG0O|FLG1O| FLG4O|FLG5O) );
// setting flag pins to 1
sysreg_bit_set( sysreg_FLAGS, (FLG0, FLG1 |FLG4|FLG5 ));
// map flags to DPI pins
SRU(FLAG4_O,DPI_PB12_I);
SRU(FLAG4_O,DPI_PB13_I);
// enabling the buffer using the following sequence: high -> output, low -> input
SRU(HIGH,DPI_PBEN12_I);
SRU(HIGH,DPI_PBEN13_I);
